FreeDSP OCTAVIA
Hello,
I am very interested in the freedsp-octavia project mentioned above. I am looking for someone who would be willing to combine an order or someone who has already placed an order and is willing to sell a single unit of the finished device.
Please let me know if anyone can assist.
Thank you.
Hi sirfragles;
there are more people in this thread being interested in a board. We decided to postpone the group buy a bit to make some performance improvements. CyberPit has made some more changes in the last days and I also have some more tests planned butI am currently waiting for my new test pcb.
@CyberPit Do you plan to build/assemble your new revision and test it?
Best Regards,
Ludwig
Reactions: vineethkumar01
Hi Ludilu-San,
Well, I have plan to ask my local committee members to join the ver0.33 board evaluation.
The difference between ver0.32 and 0.33 will Analog Series Regulator AMS1117 will change to LM317AG-TN3-R.
It will need to change the schematic design and parts layout, so I would like to update it after the evaluation.
The timeframe will be in September or later...
The change will be like this ...
PCB re-design will take some while. This change will just add a margin of heat dispassion.
CyberPit
Reactions: rrobot
Hi CyberPit-San,
I have not built the v0.3, v0.31, and v0.32 boards yet.
But those circuities are tested with modification on the existing ver0.1 boards.
I asked because I am very interested in seeing the performance with the new output circuit and the pcb layout changes. We will see once a v0.33 is being made.
Today I went to Akihabara, where I could buy LM317G.
If only we had places like this over here. A few years ago we had one shop in town that had a few components available, but the company closed all stores. Now the only way is to order online...
Anyway, good progess!
Ludwig
Reactions: Speedysteve7
Well also the same thing in Japan, In Akihabara many parts shops are getting closed and turning to Anime/Figure shops. Only a few shops keep various stocking electric components.
BTW, I evaluated LM317G circuit and I found a mistake in the upside-down value of the resistor divider. 😵
The attached circuit is a fixed PSU for version 0.33.
The resistor 110R was extended parts so I divided it into 100R and 10R.
Perhaps I can post the ver0.33 design and order PCBA soon...
CyberPit
I uploaded the version 0.33 design files to GitHub.
The main change point is the series voltage regulator. (LM317)
Some trace patterns had changed.
I will look for volunteers to join the evaluation. Among the local committee members.
So this design will be built and evaluated soon.
CyberPit
Hi everyone,
the first measurement with the test-board is in.
THD is definitly better, but my noise floor is a bit worse. This, however, is very likely due to the setup with flying cables...
So THD-N is similiar to before and THD is better. Maybe I can improve my setup a bit to get a better noise floor.
With THD of -98.7 we are probably at the spec of the DAC. I guess this will not get much better.
I'll keep you udpated if manage to get some more results.
BR Ludwig
Reactions: CyberPit
