Aleph J illustrated build guide
I should have been more clear...
The store sells the ZTX parts in their kits specifically for use in the positions you noted. 🙂
Edited to add - I acknowledge that doesn't answer you direct question about the ratings for the parts you suggested. I was only offering one other alternative, if you happen to have ZTX parts available to you.
Reactions: maltboy1
Sorry... I should type more thoroughly...
I'm not suggesting that you buy a full kit.
You were asking about a certain set of parts. I was offering another alternative for the parts and showing their validity for use in this application because they're sold by the store for direct use in those positions on that PCB for that amp.
What I'm suggesting is that if ZTX parts are available to you... then you can maybe get those (from any source you choose) instead of the BC parts you're considering.
Check pinout for both, but you may know this. Not sure how the boards are set up or if you're using "store" boards.
Edited b/c my spell check is ... grrrrr.
Reactions: maltboy1
If you look at one of the datasheets which lists the entire BC54x/BC55x family of NPN devices, like the Fairchild datasheet in the screen capture attachment, you'll see there is a member of the family with higher voltage ratings than the BC550.
If you check that device on octopart.com {and BE SURE to click "Show All" in the bottom left corner} , you'll discover there is plenty of product on the shelf today (link), ready to ship immediately.
  • Thank You
Reactions: maltboy1
@Zen Mod @Dennis Hui :
Updating you on QA process. Matched IRFP240 MOSFETs installed both channels. Looked over components and wiring once again per schematic (from the beginning of this thread + store PCBs). Observations:
  1. Making plenty of heat but not overheating
  2. LED Q2 not illuminating. New ones mounted tested and verified polarity. Odd.
  3. Power supply consistent both channels at 26.1V
  4. Both channels read 5V offset and .5V bias. How weird is that????
Any guidance on how to resolve supremely grateful to you in advance.
ALSO - I am running BC327 instead of ZTX550. I do have the orientation correct And in one channel put in a new one for good measure, the one I extracted tested good.
I presume there is jumper in R6 position
so input LTP CCS Q2 id programmed for current as (9V1-0V65)/1K=8.45mA
means that available current through R7 is half of that = 4.225mA
if we assume, say, 800mA as Iq for one vertical mosfet pair, that means voltage sag across source resistor of 0A8*0R47=0V376
taking in account that output mosfet Ugs need to be in +4V range to keep it open, adding 0V376 on top of that, we have sum of 4V375 as voltage between (say) Q7 gate and negative rail
so, voltage sag across R7 (2K trimpot) needs to be exactly that - in range of 4V375
let's deduce what value of R7 trimpot we need to set to have 4V375, with 4.225mA flowing through
4V375/4.225mA=1035Ohms
conclusion - 2K must be enough to cover needed range of resistance for R7
ok - ground both negative and positive inputs
no load at output
connect DVM No.1 across R18
connect DVM No.2 across speaker output terminals of same channel
power on
set reading of DVM No.1 with R27 trimpot to have approx. 400mV
now try to set reading of DVM No.2 with R7 to have closest to 0mV
as amps is heating up, correct one and/or another
when amp is fully heated/in temp. equilibrium, do final adjustments
