Iron Pre Essentials Kits For The DIYA Store - Register Your Interest
12V relays are also good using logic?…using separate supplies for logic and relays of course
yes, whatever you like - 48V, 24V, 12V, 5V - your choice of relays
Also, I’m curious…if 5V relays were used wouldn’t you have to change zener settings related to providing proper relay voltage?…does that affect anything else in the circuit?
that for original ( no logic) version
same as above (except no juice enough for 48Vdc relays)
zener - just use value of 4V more than relays used, to account for mosfet Ugs; in case of voltage lower than 12V, mount small heatsink on mosfet; for 24 and 12V no need for hsink
It's Alive...
and making beautiful music!
and dead quiet!
Thanks to all who made this project possible:
ItsAllinMyhead for coordinating the group build!
The almighty ZenMod for his Magnificent gift
to Greedy Boyz!!
Thanks to Pa of course for all he's done,
6L6 - for a Wonderful chassis design.
Gianluca - for a magnificent chassis delivered in
record time!
My build came up with the Power Supply ooked up.
Doh! - mixed up the IFR-510's with the IFR-9510!
After that smooth sailing.
Used the Galaxy 330 x 280 chassis
Antek AN-0218 - 25VA 18V Transformer
w/ CA-002 Steel Cover
A perfect match for a ZenMod Scryer SIT amp
and the PicorePlayer Streamer!
Bruce
