DIY Class A/B Amp The "Wolverine" build thread
Hello my friends . I'm in the final stage of assembly...and I need to choose capacitors can i have your opinions
Ground Lift PCB. Link to order through PCBWAY is here
Yeah,...I saw the board on PCBway. I now see my 10R 5W resistor is kinda biggish🙂...but doesn't matter.
Bridge rectifiers are mounted on the psu boards. But they probably will need some heatsinking.
Need to custom fabricate them from one 2mm alu plate for the 4 of them I guess, cutting them up nicely to increase the surface. Not much room on the metal side.
Reactions: danieljw
