Open source Waveguides for CNC & 3D printing!
A 1st order high pass at anywhere from 10 to 20K is a practical option to use to counteract the mass rolloff.
mainframe99's thread under his ASR handle might be useful, there is some discussion of the crossover topology there. Using the SB26 and Augerpro's waveguide
https://www.audiosciencereview.com/forum/index.php?threads/revel-m105-copy-diy-build.29465/
@Pida website has lots of designs with waveguides and crossovers posted, his design threads here have good information on the crossovers.
https://pkaudio.webnode.cz/
Just a reaction while fiddling with crossover for waveguide tweeter, the reduction in energy applied to the tweeter is significant! Must be very audible , hmmm , interesting;-)
I haven't seen any updates on the AST2560 Waveguide. Any chance the file for it might get uploaded as-is? The plots originally posted look leagues better than what I'm getting from my current setup. I would just modify it to a 170mm square and it would drop right into my cabinets.
@ post 1544 by Profigyuy. my XT 25' s are completely flat once the face plate is removed. They are relatively easy to mount on the popular Monacor W300 waveguide. That and the fact the diaphragm perfectly fits the W300 made that combi very popular in Western Europe.
@Boden - I have a set of XT25s which don't look like the faceplate will detach easily, as they have glue in addition to the 3 screws holding it. I may get the courage to try removing the faceplate and see if that picture i found is accurate for the newest gen XT25.
It is a disposable driver if the VC goes bad, so it can't be repaired when that happens or if I'm not successful at removing the faceplate.
I'm trying different rear chamber designs at the moment, so I haven't tried anymore waveguides. I'm going to try a completely different contour when I get back to the waveguides.
Reactions: conchobar
Ordered a pair of 5" WG for the SB26 a few days back and they arrived today.
The material I chose was MJF. The make and color looks good. I chose smooth finish, but still it's a little grainer than what I had expected. An image attached for reference - this is good enough to go, or need smoother for optimum performance?
Great work here.
I'm a total nube in 3D development and printing.
I have very slowly started trying out FreeCAD .... not that easy ... but will probably get there ... complex programs take time, and Iø'm not a mechanical engineer ..
What design tools are you using??
I'm today using a a SB26ADC in a Visaton WG148R, but the fit is not at all optimal, and I would like to use larger WG as well for matching e.g. 6.5" ... would be cool to DIY it
Brandon is correct - MJF is also a nylon like SLS.
What I read is that HP has done a lot of work in standardizing the MJF additive process, and most 3D printing houses are using HP printers and the quality is more uniform from source to source; for SLS it can vary.
The material feels tough, and the slightly grainy finish is also nice to touch. If I had not chosen "smooth" it is likely the grain size would have been a little larger.
Zman01,
thanks for the input, I plan too a 5" brandon's WG when I will be in the front plate design process of my next loudspeaker.
If possible, it would be great if you could do with a smartphone the cutting illustration with the router of the front plate ovoid drilling, please.
diyiggy,
I do not want to pollute this thread, but maybe this will be useful for folks who are planning to build speakers using these waveguides.
I plan to make the front baffle in 2 parts - a 6mm outer layer and a 17-18mm inner layer. The 6mm part will probably be laser cut - so I should get a nice and clean cut; it will have the elliptical cut-out for the wave-guide and a circular cut-out for the woofer frame. I am a bit fortunate that both the waveguide outer frame and woofer frame have a similar thickness of ~6mm.
The inner part of the baffle will have the truncated elliptical cut-out for the WG body, and a cut-out for the woofer basket. This will have to be done by router; the truncated ellipse might be done by jig saw, and even if it is not pretty it doesn't matter much, as it will not be visible from the outside.
Then the plan is to glue the inner and outer layers together to form a 24-25mm baffle.
I am planning to a compact stand-mount speaker with 1 mid-bass and a tweeter.
Reactions: diyiggy
