Could you elaborate some more? I'm always interested in other people's approaches and try to learn from it.
"horn load it" in the sense of transforming a regular dome tweeter into a compression speaker: no, not ideal. use a dedicated compression driver for this.is a soft dome tweeter even a good place to start if i'm trying to horn load it?
if you are trying to control directivity with a waveguide, that is of course possible, but the horns/waveguides discussed in this thread are specificly designed for use with compression drivers providing controlled wave shape at the exit of the driver, as far as i know.
regarding waveguides using dome tweeters have a look at augerpro's waveguide thread.
Not really. Both can be modeled but only as rigid body approximations, be it a flat piston, oscillating sphere or an axially-moving dome with surround. Maybe with compression drivers there's somewhat higher chance to be closer to reality (the predictions for 1" throats are often pretty accurate to ~13 kHz, irrespective of a driver used). With dome tweeters (and especially the soft ones) it's more of a luck I think, but it's definitely possible to model and use any shape of the source.but the horns/waveguides discussed in this thread are specificly designed for use with compression drivers providing controlled wave shape at the exit of the driver, as far as i know.
Elaborate about what particularly?Could you elaborate some more? I'm always interested in other people's approaches and try to learn from it.
Basically everything you wanna share 🙂Elaborate about what particularly?
Maybe...
how you made the 3d model (a render?).
Photos of it being printed.
How you're gonna assemble it and if you designed some helpers.
What material it's gonna be made of.
What speaker you are building.
a radiating ring of tiny MEMs drivers on a custom PCB? 😁 further in the throat?This is a radiating ring at the apex of the waveguide:
View attachment 1141245 View attachment 1141246
How would it sound? Probably not quite pleasantly but who knows
I know nothing about MEMS transducers (so I'm not sure about the available output) but otherwise sure, why not, it's all related to the shortest wavelength of the intended bandwidth - make all the distances small enough compared to that and there's no reason why it shouldn't work.
I'm sure they have, though don't have any examples to point to in this thread.Have Paraline lenses been simulated yet?
The narrow vertical high frequency pattern in a Paraline is a result of a (near) equal path length from the entry to all portions of the exit diffraction slot, creating a (partial) plane wave.Danley's SBH-10 paraline horn says it can control 140W x 10V using 8 paralines in a 60 inch tall horn/array. I think all he does is shift the entry port to achieve the vertical control but I'm not sure.
Though it is rated at 140H x 10V degrees, it expands to about 30 degrees vertical at 800 Hz and more than 80 degrees at 250 Hz.
Each of the four pairs of Paraline throat adapters in the SBH-10 are a different height, the outer pairs longer than the inner. Though the entry and exits of the Paralines are all physically vertically aligned, the path length difference results in the equivalent of a curved array. The entry points of SBH-10 are also slightly offset from center to shift the HF plane wave up or down.
Hello. I'm trying to create a 3d printing waveguide m2 from an stl. file (post #927) my question may seem silly, but I don't understand why the neck diameter is 33mm? it's not 1 or 1.4 inches. I plan to install CD driver 1.4 inch. Thanks
I feel that i am being inept... been trying to use the program. Not sure what i am doing wrong, but it wont recognise the *.cfg file, either in the directory or in a subfolder, as below. Any pointers to the error of my ways would be apreciated.
Hi, there is space in the path in "program files", which breaks it. Move the exe file and cfg files to a folder without space, like c:\ath\ or something.
that worked ... the challenge of windows and spaces. Should have spotted this really as running software in power shells is sort of my day job. Not a programmer - just an abuser of software. Onwards need to workout how to get a point cloud so i can import it into NX or Catia
Maybe i was a little premature yesterday...... It runs but doesnt like the mesher. Unclear from what was posted early on back in 2019 which gmsh executables i should be should be making a path to. I have tried a number of permutations without much success.
Looks like you have put a gmsh dll in the folder. There is a text file called ath in that folder where you need to specify the path to the the gmsh executable, I would also go with an older version of gmsh as a safer bet, I use 4.6.0, this is what is in my text file. I use the C:\ drive as I don't have a separate drive or partition.
OutputRootDir = "C:\Horns\4.9"
MeshCmd = "C:\gmsh-4.6.0-Windows64\gmsh.exe %f -"
GnuplotPath = "C:\Program Files\gnuplot\bin\gnuplot"
@fluid
I've downloaded the latest (non-beta) version and had previously downloaded version 4.8.0 (though I never did anything with it back then). I'm currently getting the following error in Version 4.8.2, but 4.8.0 works - running the exact same demo1.cfg file.
Any thoughts on what I may be doing wrong?
- Acoustic Horn Design – The Easy Way (Ath4)
