Alpair MAOP 10.2
Thanks Zman,
I think I'll keep my A10 mesquite cab that I did a little turquoise inlay on intact....I did swap out the 10P for the 10.3m yesterday when I discovered the MAOP wouldn't fit and decided that I like the m better than the p. While the m is a bit more cruel on recordings with grating highs, overall I like it better...not by a ton, but better none the less. The margin of improvement, though to me isn't as much as swapping a 7P for a 7M (which I've done on my 2-ways).
When my back gets better and woodshop waitlist eases, I'd like to build another floor compact for the MAOP..
Mario
Here you go Dave...I think I posted this but it was many years ago: a Bob Brines bookshelf cab design for A10P or A10M. I bought the flatpac from him, assembled and then glued mesquite panels that were ripped, cut and planer'd down to 3/8". The "cracks" in the mesquite were inlayed with crushed turquoise mixed with apoxy....I think they look better now with the copper colored A10.3m and will eventually take pics of that.
Mario
Hi all. A pair of MAOP 10.2 drivers are on the way. Looking for diy cabinet recommendation. Gotta have the best of the best, right?!? OK… Within reason. Not sure I want to dig into some of the room sized or highly complicated builds.
Will be running Elekit 8900 2A3 in a medium small room.
Currently using Lii Audio S10 drivers shoehorned into Madisound/Fostex 8” BLH kit. Yeah…I know! 😬 But not as bad as you might think...and with a pair of REL T7x subs gently tucked under most are amazed with the sound. This was supposed to be a temporary set up, but I have been running these for two years now! (Still looking for a better cabinet design for the drivers).
Meanwhile, I have long been interested in the MA drivers and thought it time to give them a go. Thanks all!
(my opinion, and perhaps biased) Frugel-Horn XL, Pensil, Silbury (if you wanna go nuts), and if those are too big, Mar-KenM10T (you’ll need stands), then the easier to build ones.
The first 2 have the most flexibility in terms of tunign the bas sto suit the highish output impednce of the 2A3 SE (an amp i’d lik eto hear).
dave
