Better late than never. It has many good things like the air core coils, opamps drivings its inputs. Less good is the mechanical noise by some ceramic caps. I sold it today in heavily modified state and already miss it...so I bought another one as it is even cheaper today.thank you, from someone who doesn't know enough to get anything from reading the datasheet.
If you will, what in particular do you like about the A8 design compared to some others?
That one will get 1 µF WIMA 2.5mm caps, 3 x OPA1642. Will see if I can solve the mechanical noise of the caps.
What do you plan to do to it - if anything?Well, bitten the (ok, affordable) bullet and ordered this module:
https://www.aliexpress.com/item/100...store_pc_home.smartJustForYou_6000601971963.0
Will be interesting to see how it compares back to back with the basic TPA3116D2 that precedes it.
The newer A02 revision (17-03-2022) of Aiyima A8 has a “mystery” part……..
Got it today and operated the patient directly. Sorry for taking a picture after the mods. It now has 3 x OPA1642 and Wima MKS 1 uF in 2.5 mm pitch. It is breaking in as I write this 😉
Please find the differences.
One is U13.😎The newer A02 revision (17-03-2022) of Aiyima A8 has a “mystery” part……..
U13 Looks like a microcontroller to ensure graceful startup and shutdown? The datasheet shows that an I2C interface is needed to set parameters. That is, the amp cannot run without an MCU to load its operating parameters each time. It’s too smart. 🙂
Well a friend popped by, I hurried to finish it and …. POP. That is a goner…
Pity, it sounded very good. Still don’t know why and the chip is cracked so EOL in just 1 day 😀
Ahh that’s too bad. Can you remove and install a replacement vs trashing the whole board.
I have only had a Class D amp pop and crack on me one time - a TPA3255 under stress test for high power and I had dummy load on only 1 channel and forgot I was driving input to both. The side with no load was not happy due to back EMF from LC filter.
It is already trashed. Can’t stand making stuff kaputt.
I think it is the soldering of 4 x 100 nF MKS at the inputs. Forgot to connect my ESD wrist strap. A first and a good lesson. Also it lacked the 6 x 1000/35 bulk caps as I ordered those. Searched and also found a miniscule piece of solder tin but not at the pins so I can’t find a root cause except being in a hurry which is one of the worst reasons.
Gain was lower than with the previous one. Sounded pretty good, better than a vanilla Sabaj A10a. That A10a better stays vanilla 😉
This amp is clearer than my modded 3e tpa3255. I have almost no desire to change this
Thanks for the recommendation.
where are yall buying this from (to make sure it's the A02 revision)?
Is it from Aiyima.com website or Amazon, or? Please provide the link, thx.
Got the new one and the patient got an operation directly as usual. The patient survived and is playing now. 3 x OPA1642, 6 x 470 uF 35V Panasonic FC, 4 x Wima MKS 1 uF 2.5mm. Good stuff, sounds great with deep and tight bass.
Got it from Aiyima which sells stuff on Aliexpress. Requested the A02 version and got one but it could be that all recent ones being sold are rev. A02.
A casing has been drilled/prepared for a regulated linear PSU 22V 3A (LDO). A bit on the light side but when results are OK a 5A version will follow.
JP,
Those are all high quality mods and not very expensive. Any photos of the patient, post operation?
Could this less expensive variant from AIYIMA work as well?
https://a.aliexpress.com/_msV3zTu
Hi Jean-Paul,
Do you think that it sounds as free/direct as a (my) top tweaked STA326 FDA ?
(I know that the global DAC+AMP distortion and SNR are better than my FDA).
That might not be made by Aiyima. It shows up in searches for "KGUSS D70"JP,
Or AIYIMA makes it for other companies. I have seen same stuff under brands Nobsound, Aiyima, Breeze, BRZaudio, etc.
This one is only $24 and lots of room to play doctor.
https://a.aliexpress.com/_mPVLI74
- Class D
- Infineon MA12070 Class D
