DIY Front End 2022
fact - some ppl are taking one Vbe as 600mV, some as 650mV, some as 700mV
ignoring that really depends of exact part and current trough, it is basic figure used as guide; tight guide, but not exact number carved in stone
Just now I measured the Vbe of the actual KSA992 (PNP transistor used in Nelson's Front End design), in my lab. Measurement conditions were:
  • Vce = -20 volts
  • Ice = -9.00 mA
  • Air Temperature = 23 degrees C
  • Number of parts tested = 10
And the ten measured Vbe values (using a 4.5 digit DMM but recording only the 3 leading digits here) were:
630 mV , 629 , 626 , 631 , 629 , 625 , 628 , 627 , 628 , 628 mV { yes Vbe is a negative number for a PNP. no I didn't type it }
These data have a mean of Vbe = 628.1 mV and a standard deviation of 1.8 mV. Please feel free to use measured values of Vbe in your circuit analysis / hand calculations, and as a rough double-check of your simulation models.
You now know that the drain current of input JFET device "Q1" is equal to (Vbe / R6) which is 924 microamperes, when Vbe=0.628 and R6=680. Of course a different value of R6 and/or a different value of Vbe will change this. If the tail current (supplied by Q3) turns out to be 3000 microamps, then 31% of it flows in the left leg of the differential pair (Q1), while 69% of it flows in the right leg of the differential pair (Q2). The diff pair isn't perfectly balanced, which might lead to an increase in second harmonic distortion.
Reactions: Monk55
Hello wwwtttwww,
I have tried the full Fet-frontend as described in Nelson Pass' article (DIY Audio OpAmps) with Zetex ZVN3310/ZVP3310.
I wouldn't use the MosFets in the long tailed pair (first stage) anymore. The sound was slightly 'dark' or it seemed reduced in the
highs. Perhaps a result of the Ciss of 40 - 50 pF?
I prefer JFets in that position (LTP) - or a good pair of BJTs. It could be worth a try to test a P-channel JFet or a P-MosFet at the Q5 - position of the FE2022.
Try it.
Cheers
Dirk
Reactions: wwwtttwww
Nobody seems to be in a great hurry to discard the KSA992 PNP transistors that Wayne Colburn designed-in to his BAF-2018 Linestage, a circuit board that's currently for sale in the Store.
_
Any reason Not to use J111's?
I built this with parts on hand so J111 and ksa992 and as far as I can tell it works well
just had to change the CCS resistors to get 3ma / 9ma
This is neat! Thanks!
need to order parts and refresh how to measure Vp again
Reactions: Aleph5
