NAD 3130 conversion to Lateral FET
Joined 2021
So im making a start on this as the 3020 i did was realy succesful
Bit more difficult with this one as there is no provision on the board for the TO-247 pattern, so im going to have to be creative
The circuits are very simlar in most ways to the 3020 so it should be straight forward in that sense, but not so in other ways
will progress updates as i go along 👍
Reactions: gadut
so i will elongate the heatsink to facilitate the legs of the transistors
plenty of room and scope to improve the heatsink
so the old heatsink is out and modified-ready to clean and have a light spray
i will clean up, re cap and prepare the board while it is out-the burned area components are actualy ok, must be an old scorch mark
never seen these installed in a 3130 before
so all cleaned up, and re capped, only took an hour using the hakko
now almost ready to do the buisness end
new mains lead and converted to mains earth
so have a look at this, first pic all cleaned up, it was rotten, and no issues
but what about the other one, no wonder that circuit was burning
what would you do with the op amp then?
Knowing how you like to experiment with these things it might be worth trying something different (the 2043 is like a 4558 which isn't particularly great even though it is very common) but I see the supplies to it are in typical NAD fashion a bit weird. Nothing that can't be solved easily though. Maybe something like a an OPA2134
as it happens i wanted to do this one without the VBE and drivers
We did a sim of the one with no drivers:
I would get it to work first with the multiplier, then think of removing that if you want. Ideally we fit a fixed resistor in its place because the current might be a bit high to feed into a preset wiper.
they do look like it, but to what end,
They definitely look like deliberate cuts to me. Scrape the lacquer and bridge with a cm or so of wire.
dry fit first N channel see how it sits, quite nicely as it happens, the board side is the tricky bit and i learned alot doing that first one, so this should be alot neater
just check i have this correct
That looks correct. Remember the multiplier has to be set to give minimal voltage between the gates. Do as we did on the one you have already done, and I can't remember what val;ue preset you used for RX1 but around 2k sounds in the right ballpark so perhaps a 2k2 or 4k7 preset for RX1.
If you use the bulb then provided the FET's are fitted correctly they will be safe.
