3 way upgrading Jamo D590 replacements and filter question
Welcome Pelleplutt ( kul att du hittade hit)
Your Jamo 707 will play much better if you makes the modifications this tread is all about.
The tweeter SB26ADC is MUCH better and cleaner than the orginal Jamo tweeter, it´s "night and day", and the Faithal 5FE120/8 the same.
Much more microdetails fast and gives a punsh.
Did you se my earlier answer in the tread about recomend modificationation on the xover for Jamo 707 ?
Best regards John/Uppsala län/Bålsta
Thanks alot jawen/John!
I started out by re-foaming the surrounding edges on the four bass elements. Then I ordered new caps for the xovers but they are still unpacked. Too much other things to deal with. A three weeks visit to Tanzania almost emptied my bank account so I am kind of lost in the snow. So new speaker elements, well, I need two tweeters, four midbass and four bass (push-pull) - I guess currently that is not my wife's priority. And she makes the money, I am just a retired poor man. 🤔 In addition I am not as technical as you guys are. Things move slowly when I am in action.
Anyway, I keep following this thread with great interest, eventually and hopefully getting my hands on the speakers and then I will return with questions, rest assured!
No new woofers yet but got a old eq to play around with, felt like the amp got some loudness boost or something so i wanted to boost the midrange a bit instead.
Reactions: AllenB
Start with the filter, it made a BIG difference 👍🏻
Must be fun to play around with 🙂
And i also did that "in the old day´s" ( 1988-1999 ), now i try to keep as few component´s in the chain as posible but that mean it from the begaining have to be good sound from the speaker, amp and room and that´s trickey.
Reactions: Belemakare
yeah you are right,but in my case everything is better with the HK amp BUT the midrange sounds better on the yamaha so thats irretating as i listen alot to 80-90s metal rock and blues so guitars and vocals are important,if i remember you had a drop at 3k herz? And that is what i think i can hear in my home
Where to stop and be happy?
After some time listening i have come to the conclusion that the upper range is kind of thin and metallic sounding..
Is it me?
Is it that it is higher resolution in the sound that show of flaws in the recording?
Is it the amp? It do have an open and sharp sound..
Toughts?
Do i need a more warm sounding tweeter? Amp?
If i should change the tweeter,what tweeter should i have?
It sound fantastic on good recordings but both the speakers and the amp is really revealing and i thought i wanted that…
Ahh getting crazy here 😤😊🙃🎸💥👻💇🏿‍♀️🍺🐓🤛
Can you remind me what your mid and tweeter Xover components are? Are they the same as Jawen's design?
I think the SB26 has great performance for the price. Getting a tweeter fully integrated and tuned to your satisfaction needs careful consideration of level, how the level matches the mid range and ideally follows a flat or downward slope to get a nice power response..
At a simple level and without a microphone to measure, you could try inserting three ohms in series with the input capacitor to the tweeter Xover?
The resistor in series with the capacitor should allow you to tune level easily. A 5 watt power rating should suffice whilst you experiment, you can even use smaller wattage to test. If it goes quite you will have probably have popped the resistor. I have seen half watt resistor's used to act like a fuse, if people turn the volume up at parties.
Difficult to say without measurements or modelling to help.
Maybe a bit of a classical dip would help between 2-3KHz. Have you any modelled information and it will be worth digging out the values you used for the exact Xover.
I know its in the thread, but what version of speaker do you have, and if I remember correctly you also made some new baffle pieces for the 5FE100/5FE120 ? Care do post some images?
Thanks for the images and the clarification.
Some thick felt would be a quick and cheap fix , I.e. the 1 cm square type stuff used around the ls3/5a tweeter, or alternatively some thick felt carpet felt cut that into strips.. With Measurement you would be able to see how effective this can be.
If I get round to a D'appolito with two 5fe100 and the SB26 I will post some further info. They are good units.
I did the modification of the filter described in post #127 page 7
Hallo agian folks 🙂
You haven´t done the "final" modification on your crossover Belemakare, so hard for me to tell!!
The final xover was on page 13 post #254 including "how you do it" and
2 X 15uF caps
12uF cap
one 1 mH coil
2,2 ohm resistor
/per speaker
Post 127 was only 3 caps
Have to fix food for my daughter now, but will be back.
Best regards John
The biggest problem i think is that its hard to get an open clear sound with high res without it getting to ” much” with some music
80-90´s cd album and recordings is real trickey to get playing "perfect".
They often sound thin and a little nasally ( much like you described your problem)
Vinyl records often be a better "source" there, because the music is compressed too much, and those who master (finish) the CD/MP3 at the time, often try to "hit the biggest market" and that was carstereo industry/radio...
And carstereos often dont even play frequencies below 50 hz and is surrounded by noise from wind, tires etc, so almost never any hi-end resolution.
And the better your stereo system is, the more you will hear from bad recordings ( and sometimes thats a problem)
I way to tackle that is to have 2 different settings in your receiver, so you can change with the push of a button when listening to such music.
Because of your use with "only" 3 caps xover modification ( insted of the full one with Peerlees woofer) I think you maby have 2-3 dB "to much" between 1300-3000 hz, and after that a drop......that can enhance your sense of "in your face" or a little fatigue over 3000 hz
Best regards John
Thanks for your support! Yeah i took the easy way with the filter but i think its time to do it all the way instead,i unplugged the eq.. every time you listen you just stand there and tinker with the settings…😤 and the sound is a little bit more ”calm”? Without the the eq
Reactions: jawen
