BAF2022
Hi Nelson, when can we hope to see your pdf to the new pre?
I got better. A blurry screenshot of the schematic of the Front End. :magnify:
Reactions: generg
:Popworm:pinout for 2SK170, 2SK370, LSK 170, 2SK2145
J113 - manage, isolator bushing on one pin is solving rotation of same, if needed
same applies if you want to use BC639/40 instead of ZTX
depending of rails voltage, resistor or two needs change of value, trivial
  • STASISSY FE Gerbers.zip
Ha! No, I was just trying to understand the schematic. Is your ‘-IN’ part of a differential signal, or is it just ‘audio GND’ for lack of a better term? I admit this is rudimentary stuff… :deerman:
same as screenshot of Papa's schematic in #88, this is having positive input, negative input, input GND, SE output (in phase with positive input) and output GND
so, SE/BAL input, SE out
dual rails
making it for single rail is trivial, but I'm leaving Pa to proceed with limitless overindulge of Greedy Boyz
tomorrow someone will ask for A Class amp with Solar PSU, 100W/ch, complete stereo kit for 100$, Canadian
:devily:
