Cheap ADSP21489 + 4in / 6out PCM1798 board
No worries. There are six i2s connectors on main board 4 for outputs and 2 for input. They are used for expansion 'cards' like DAC, ADC and spdif I linked. See photo with pinout.
Thats how I would try to connect RPi on this board. Of course I cannot guarantee it will work.. It should but you never know.
Problem is that board is closed source, now you cant even connect dsp to sigmastudio, so you able to use provided PC software only.
If you need option that is not in software, or some functions not working well then its a big problem - Nvarcher shop support.. and most support on aliexpress is terrible they will answer 1 sentence a day max.. I've been trying to get software/schematics from them ( which are necessary to work with dsp) and.. I gave up after 3 weeks of conversation(!). Was lucky to download from other source.
I wrote earlier - if I had knowledge I have now before I wouldnt buy it, I would get second hand minisharc board which has good documentation and support.
Would save me a lot of nerves. Think twice if this board is what you need
See your point here ! If i will buy its safest to buy a separat converter box spdif to usb or somthing like that….?
Thanks again !
I use google translate, sorry
I ordered
SA9227 Nvarcher USB sound card playback recording two-way I2S IIS SPDIF coaxial input and output 384K ASIO
https://www.aliexpress.com/item/1005004231589065.html?spm=a2g0o.order_list.0.0.21ef1802mOsLJr
I have a question
Can I have it
R19 Raspberry Pi Pi4 3B 4B HIFI digital broadcast webcast optical fiber coaxial I2S 384K DSD512
use in I2S slave mode with ADSP-21489 Audio Processor 4 In 8 Out
https://www.aliexpress.com/item/1005003747105906.html?spm=a2g0o.order_list.0.0.1dbf18023YdgyV
https://www.aliexpress.com/item/1005004252322905.html?spm=a2g0o.order_list.0.0.1dbf18023YdgyV
I ordered
I have a question
Can I have it
USB interface seems fine.
So how you want it all connected? And what you gonna do with i2s over hdmi?
RPi have one i2s connection. Look at pinout. And you connect Rpi to one of inputs on dsp board - IN A/B or IN C/D look for pinout on schematics for those.
DSP-Electronic-Crossover-ADI-SHARC-Development-Board-ADSP-21489-Development-Board.jpg
Then in Moode Audio or volumio or whatever you choose chipdip-dac(99% sure it was this one) as output, and set resampling to 96khz.
Its tested and working
Is it OK?
So you connecd RPI to DAC same way. If I remember good mck was not needed. Yeah double check orientation if you connect right pins on DSP board.
I get nothing on CN1 AB IN
I connected the mirror
As before, I get intermittent noise that mixes with the music
