2P29L Preamp
I also removed the aluminium shield. But funny thing is that, I cannot see the flame of the filament and all the measure are not quite right. Can you see the flame of the filament? Maybe I am not lucky enough and bought some flawed tubes.
As I recall it was pretty much invisible. I've noticed the same thing when I've had other "battery" tubes on the breadboard, very little glow and they don't warm up much at all even after being run for a long time.
You should be able to measure the voltage at the socket, however.
Own experience.
I lost hundred years tube, when it decided (tested in not fixed socket) to wrong direction and the sagged filament contacted to grid. 😢
From this point of view the most sensitive filament type is in right.
If you use this horizontally the hot filament sagging, and can be soldered together to the transport rod.
The "M" or 'W" type (spring tensioned) filament is more tolerant.
Just a question about how to connect screen and grid 3 on the 2P29L. I've been using 100R resistors and connecting both to the anode. So:
  • Do you need any resistors at all if running the tube at around 150V on the anode?
  • Any reason to connect grid 3 to the cathode or just connect both to the anode?
Max g2 voltage 150V, max g2 dissipation 0.7W. There are no curves in the datasheet to estimate g2 current at 150V, but taking into account that g2 voltage will never be higher than the anode I would say you are pretty safe connecting g2 directly to the anode.
  • 2П29Л.pdf
    2П29Л.pdf
The lamp has different characteristics from the years of release. For example, if the anode has a permissible voltage of 150 volts, then on the second grid 120. In the passports under the above link, this is visible.
I have some basic Russian and this particular data says max voltages are 200 anode and 150 screen, dissipation 2W and 0.7W. Grid 3 at 0V. I don't know how to tell if the valves I have conform to this. Mine are in green boxes and appear to say "laipa" or launa on the box.
Any preference for grid 3 connected to cathode or anode via 100R?
There is a pre-amp at Bartola's (https://www.bartola.co.uk/valves/tag/2p29l-preamp/) that uses g2 and g3 tied to the plate with a 300 ohm resistor.
I found such pictures, think for what's what. The second is apparently the R-106 radio station (I'm definitely not sure), and with below someone was signed that the conclusions of lamps 4 and 8 together.
