The marriage
Greedy Boy Lego
Did you just Babelfish the M2 again?
Except this time it's the Babelfish M2 OS (PoP version) with the M2 FE ... but it's a completely different amp (because it's missing the jfet buffer)
Stephen
it already happened to me in reality** - literally completing paper part of project of same amp , twice in 10 days
and when I realized it, comparison did show that I made it with irrelevant difference between original and next Groundhog Day
**mine is really tricky one; luckily I stopped fighting and being surprised;
choose:
Yesterday I had a bit of spare time and put together the asc file for the boo to understand better how it works/performs.
First thing that I did was a thd sim and after that I did an output impedance sim.
For the output impedance I got a very high value. What I am doing wrong that I get this high value?
can't tell, don't care for Rout, because I know it is much lower than if you have source resistors
though, I believe ( if I interpret your formula properly) there is an error - you need to compute it as Rout = DeltaU/DeltaI
and for that sim, you can use just one phase/half, with 4R load as base
anyhow, with Cordell's 240/9240 models, I just got 0R13 per phase
double that for bridge - 0R26
means damping factor 8R/0R26=30
not bad for no-FB construction
I do the calculation as you say: (V(o+)-V(o-))/I(V6).
V(o+) is the voltage at node o+ which is positive output
V(o-) is the voltage at node o- which is negative output
I(V6) is the current that goes through the voltage source that I use to measure the output impedance.
With 4r as base you mean having the load connected?
I still need to learn how to play with new models, it will be soon.
So into 4ohm I am getting something like 15df(4/0.26) with the boo and was getting 10(4/0.4) with the aleph j.
A very nice improvement that I felt from the first tracks that I listened.
no need for overcomplication
Case 1 - run sim for nominal load; read voltage across load, read current through load, write down both
Case 2 - run sim for (say) 50R as load; read voltage across load, read current through load, write down both
then Rout=DeltaU/DeltaI
where Delta is (Case1 - Case2)
This time I went for something more realistic.
I chosen 190hz because my speakers get to 3.4ohm at this frequency being 4ohm nominal. I did the measurements directly with the speaker as load.
The bias was 1amp.
To see if the thd profile changes I used 2 different line stages. Iron Pre was one which is UGT in the description of the photo, the other one is a bba3 and is named UGX in the description.
Today I had a bit of courage and moved the small signal gnd.
I am still waiting for the isolator sheet and (for a week now )I am searching also for a used torque screwdriver. Not much to find around.
When doing it only with your hands, how can you know that you tighten enough? For 1nm you need to apply ~100g of force.
What happens if you over tighten ?
nice to have, but not necessary for DIY amount of work
I am more on this side. For now I don’t have so many amp pcbs to replace inside the enclosures so I will take my chances with a kitchen scale to make an idea how much force I need to apply.
Today when I searched for the oil(to make the threads in the holes) I found some rc bullet connectors.
The females could be soldered perpendicular to the pcb and the males on the wire giving a very simple way to replace the amp pcb.
For small currents 2mm is ok and for big currents 5mm. Never seen someone using them in an amp and I was thinking to solder a few on my pcbs to give them a try.
I am attaching the ffts for both front ends that I used in my previous test.
One of them is h2 dominant but the other one isn’t.
In the test I got the same thd profile for both.
Could it be that I used the irfp150 on the negative phase and this changes the things?
