DIY Class A/B Amp The "Wolverine" build thread
Hello Fellow Techies, I'm Aaron. Pretty much new here on Forum .
I'm a 80's & 99's Stereo -JUNKIE from head to toe. 😂 Lol Raised up from the country and as a boy I had enjoyed the VERY Stereo I'm listening to today. My folks purchased from a nearby dealer .
✓ 1987 Fisher HiFi Studio Standards
. 220W A/B. Amplifier
The RS-884 TUNER AMPLIFIER
QUARTS Locked FREQUENCY SYNTHESIZER DIGITAL TUNING SYSTEM.
✓MODEL STV(SPEAKERS)15" 3-WAYS
+ Made DIY 9"MTM's Floorstanders Rms180 @ 8ohms(wired for 4 OHMS)
MONO 10"SUB(PLATE-AMP)
PLAN:
I WANT HELP WITH PREPARING MY PARTS LIST ORDERING AND Prepare FOR A SOLID FOUNDATION TO THE BUILD. IF ANYONE IS WILLING TO HELP ME HANDLE THIS, ID BE VERY THANKFUL FOR COMMENTS. EVEN IF THEY MAY BELIEVE I NEED TO RETHINK THIS CHOICE, IM LISTENING.LOL THANKS SO MUCH...
. I can't find SPECS as to how much power THE*BADGER*CAN PRODUCE
PLAN:
Firstly, the use of capitals is like shouting and is very rude. Its the best way to annoy people.
Next, this thread is about "Wolverine", a seriously improved and consequently more complex design that builds on the Badger. Wolverine is an EF3 and is capable of driving low impedance loads (speakers) at what ever level your power supply and heatsink will support. Typically people can expect 200W into an 8 ohm load with a 3 unit DIYStore case and a 50Vdc power supply. (If you do not understand any of that jargon please ask)
Further information, parts lists and build guide are found at page 1 of this thread.
Like many others I have been earnestly reading the design doc and watching the build videos of this amplifier. Looks very promising. I will be attending BAF this weekend and would love to chat with like minded enthusiasts who have built or are building this amp. Thanks to Stuart et al., for all the efforts. Given his recent timeline post, I expect the boards to be delivered in December sometime which is perfect timing for the holiday build queue. I will also converse with Gianluca this weekend. I don't know if I will go with a 5U/400 UMS or get a custom 4U/400 for my EF-4 build.
Best,
Anand.
Anand:
I’ll be at Burning Amp both days. Happy to chat with you if we can find each other.
Scott
Reactions: danieljw
Hi Stuart,
You asked for pics. It may not be the neatest build, but it is the best I have heard.
Once again my thanks to all the team.
Ashley
I just completed a EF3-4 using Sanken outputs and Toshiba drivers, and wanted to share the following measurements with you all.
First test - Frequency sweeps from 20Hz to 48kHz @ 25Vrms into a 8ohm load every 5 minutes for an hour from dead cold power on. I ran this test to check stability and distortion over the time it went from cold to hot, as you can see that amplifier is very stable and does not drift.
Second test - Heat soak running band limited pink noise 20-20k @ 1/8 power(25 watts) for 1 hour, then ran the same frequency sweep as before and compared it to the proceeding sweeps. Note the scaling is highly zoomed in, yet the amp held the low distortion as before.
Third test - Power sweeps to clipping at different frequencies, and to see how well the distortion holds up at higher power levels. The amp runs around 190 watts @ 0.1% with 60 VDC rails from 20-20kHz.
Fourth Test - 1 kHz FFT @ 25 Vrms into 8 ohm load. I am using a 1kHz notch filter in this test. ----0.000027% THD | -131.37 dBr----
Hi Stuart,
Ashley
Your build looks great, absolutely love those green boards. I'm so happy that you have completed your build and your happy with the performance. Thanks for posting and I hope you enjoy listening to your favourite music.
Reactions: dazcwl and danieljw
This is some great work Andy - Excellent results.
