SissySIT R.3
Joined 2011
pull them, snap on just one (X side) pin, so V pin left free for measurement
Thanks again ZM! Done, and here’s the porn to prove it.
Official Court Jester
Joined 2003
Reactions: 1 users
Joined 2011
While I'm waiting for caps and monoblock chassis and other stuff to arrive, I thought I would start sketching out a wiring plan using the boards Zen Mod provided with the SissySit R.3.
I am going to implement a CLC for each monoblock using 33mF Caps and Hammond 159ZJ chokes. I adapted the Mains NTC boards to work with the F6 PSU diagram, which uses 2 CL-60s from the Mains to the transformer.
I banged out these pictures quickly in MS Paint, so they are crude. After I finished I realized I could have drawn the Mains NTC wiring without having to cross wires on the picture - it's not worth going back to correct :headbash:
Is there anything tragically wrong with my layout?
Before I start stuffing the amp boards with the parts thought of creating a BOM of all the parts included in the kit based on the schematic. Here is the excel sheet for both the channels that I could find on the schematic and I am yet to reconcile this from the kit of parts that mighty zenmod shipped in the package. I believe his kit is top notch with all the parts exactly per the schematic.
I hope I have not done any mistake with the qty and part numbers.
  • SissySIT R3 BOM 1072022.zip
  • SissySIT R3 BOM 1072022.pdf
Reactions: 1 user
Documenting my sissysit build here
I think its a LT3092 instead of 3062 based on schematic
Wouldn't worry too much about qty, you'll find a place for all the parts, and all the holes should be full when you're done.
Reactions: 1 user
@Zen Mod need a clarification with the kit that you sent me, I see that I got 22uf/16v Silmic caps instead of the schematic 10uf/16v for C104/204. I hope 22uf is good enough in this position. Also the C107/108/207/208 schematic says 470uf/16v and I got a slightly different value in the kit. I hope these replacements are good.
Little more progress on R3 today -
Made some cables for the bridge rectifiers to the PSU boards and tested the output voltage with all good so far.
Reactions: 1 users
Joined 2003
input Silmic - more the merrier; when I was ordering them I saw that I can get 22u for same price as 10uF, so why not
caps between output gates - whatever I sent you is OK, going from 330uF to 1mF, voltage 6V3 upwards
Reactions: 1 user
