USSA-5 PCB GB
Your manual is well done. I had commented your manual a few weeks ago on my ipad…..but the file was not save with my comments 😡for an unknown reason….I will have to include my comments again into the document….maybe I can simply provide them in a list by email….
Fab
I'll put the manual as an editable file in the dropbox this afternoon. Maybe that's easier 🤓...
Reactions: stretchneck
After one or two verification builds I think it would be the easiest when I upload the gerber files in the thread so that everyone who wants to build a "big one" could order the helper boards by him/herself...
fab and I are exchanging about the documentation. I have to do some graphics to clear the interconnection between the different boards ("wiring diagram") and then it could go into the hot phase...
Hi Pinnocchio
v 0.8 USSA pcb is a mini version for lower power amplifier to integrate in a small chassis. I use this pcb in my portable all-in-one music server/amplifier. In that case it is for an USSA-4B version. See attached pictures. Useful when I want good sound in a remote location rental cabin in the woods….
Fab
Reactions: manniraj
Sure it can be used as a headphone amp. But in that case I would not install the power ouput transistors and rely only on drivers since they operate at more than 50ma which is quite enough for any headphone in class A region….
For headphone you can also use USSPA pcb with jfet input.
See below this USSA v0.8 pcb used in a preamp with bjt input and only drivers as output. Note the input cap on pcb is bypassed with a wire. However I have used a speaker crossover cap to protect the TKD potentiometer….
Fab
