'Upgrading’ my tweeters (can I do this?)
First put a jumper over 1R5 and listen if you like it that way. Then add 0.22uF over both blue capacitors. Then do what ever you want next. :Popworm:
It would not be bad to do air core inductors if you make a new crossower, but to be approximately the same DCR as the existing ones or a little less.
For 1.63mH and 0.3ohm DCR a 1.8mm diameter wire is required. There is no chance that this new inductor will fit on that existing PCB.
Not completely. We want to draw a circuit diagram. We need to see where the components solder so we need a clean shot of the other side.
Or have you already drawn the schematic?
this good?
The tweeter looks like it is wired in opposite polarity
the lugs on the bottom pic on the left side are the red + side
i have the measurements of the inductors on the other thread.
dumb of me however that I didn’t measure both speaker inductors
You should have measured. However, they are wound automatically with the same number of threads so that they do not have large deviations, if they have the same ferrite core. When you wind a few air core inductors with the same dimensions and number of turns, they deviate very little, negligible.
Reactions: tone?
Funny I just measured the left speaker inductors.
tweeter is the same
bass. On the left is 1.50mH and DCR 0.3ohms
bass right is 1.63mH and DCR 0.3ohms
