PCM1702P
BOM example: https://www.mouser.com/ProjectManager/ProjectDetail.aspx?AccessID=595c0b2ddd
https://ctrlv.link/shots/2023/04/03/vCjl.png
If PCM63P can be done, I will be the happiest man in the world.
+1If PCM63P can be done, I will be the happiest man in the world.
It will be in a short timeIf PCM63P can be done, I will be the happiest man in the world.
Rise of the DACs If you can please check the PCB if everything is OKReally Miro! Just so happens I have a few 1702’s buried in my stash for years. Maybe they will finally be put to use. Thanks for sharing yet another project.
@miro1360, can I use the PSU-1 with double stabs on 5V? I think this is better DAC (1702) instead pavouk project on smd. I don't like smds😄
I will seen all components for your dac and I know where I can get 1702P-K))
By the way - I buyed a two 1862N-J but I can't see a difference between grade N. I am install the pair chips (N-J) with same part numbers!
You're a legend!It will be in a short time
As for me - 63 is worst than 1704. The last one is another level of sound. 63P-K is a little muddy. Doesn't emphasize on instruments just like no pause between instruments. That's not bad but it's a disadvantage.If PCM63P can be done, I will be the happiest man in the world.
I have Akai CD-79 and also listen Lynx D27 (Lynx audio).
PCM63P-Y is the very RARE (limited) edition. I get it in person from Mighty @Zen Mod taken from some Sony dac studio console.As for me - 63 is worst than 1704. The last one is another level of sound. 63P-K is a little muddy. Doesn't emphasize on instruments just like no pause between instruments. That's not bad but it's a disadvantage.
This chip is as good as TDA1541A S2 double crown.
This is the problem, you will need the adjustable version (or modify the components for fixed version based on datasheet)3.3V and 5V. Not adjustable.
- Digital Line Level
- DAC AD1862: Almost THT, I2S input, NOS, R-2R
