DAC AD1862: Almost THT, I2S input, NOS, R-2R
  • diyAudio_PCM1702P_DAC_v1.4_uf.l_2022-06-13.zip
@miro1360, can I use the PSU-1 with double stabs on 5V? I think this is better DAC (1702) instead pavouk project on smd. I don't like smds😄
I will seen all components for your dac and I know where I can get 1702P-K))
By the way - I buyed a two 1862N-J but I can't see a difference between grade N. I am install the pair chips (N-J) with same part numbers!
As for me - 63 is worst than 1704. The last one is another level of sound. 63P-K is a little muddy. Doesn't emphasize on instruments just like no pause between instruments. That's not bad but it's a disadvantage.
I have Akai CD-79 and also listen Lynx D27 (Lynx audio).
PCM63P-Y is the very RARE (limited) edition. I get it in person from Mighty @Zen Mod taken from some Sony dac studio console.
This chip is as good as TDA1541A S2 double crown. 😎
