Q17 - an audiophile approach to perfect sound
Like I said
I took a risk now and powered up the amp without the fuses in dc rails. I see that in few seconds the trace near the negative supply next to the cap burnt up. Silk screen is damaged but the trace is intact. I switched off the amp immediately. It is still with the FQP3P20/FQP3N30 mosfets. All mosfets seem to be fine post this but not sure why this trace alone got burnt up. Even the mosfet here with the bulb tester was getting hot even though the other power mosfet was not even warm.
Which version of the boards did you get it printed now?
Mini version. I put the coil away.
Made the input filter
It wasn't a very good idea. If the fuses blow it's for a good reason.
Q16 must be shorted (dead). Check R between GNDPWR and NEG rail.
Stef.
You have a short contact somewhere. Disconnect all cables and check resistance between GNDPWR and positive rail and negative rail. Check resistance between Q5, Q6, Q15 and Q16 metal part and GNDPWR. Should not be zero Ohms. Same with dissipator.
Stef.
Sure thanks Stef will check. When you say check resistance between Q5/6/15/16 metal part you mean each leg of the transistors against the ground power on the supply side?
One more thing, you have C7 as an MKS? That's a rather compact film capacitor in your case, isn't it? You don't need the yellow one at the input because of the DC correction of the amplifier, does it have approx. 1uF and can you install it as C7 as a test?
The point is that your symptoms mean that the OP cannot find the operating point. I have such effects when R13 varies slightly in value. In your case, it seems that the OP has a problem in the feedback.
I looked at your PCB, it looks like Q9 + Q11 are installed in reverse, is that possible!
The metal part with the green cross. Check isolation of power transistors from heatsink too.
Stef.
Stef.
Thanks Stef, I always check each of the mosfets metal base for shorting to the heat sinks or not before powering up. I also checked each leg of the mosfet against the heat sink for shorting. None was their as I use a silicon thermal pad and grease. But I have not checked the ground power to the negative/positive rails and against the mosfet metal part. Will check that and for the last try will replace the FQP3N30/FQP3P20 with 610/9610 and run the amp. Also what do you suggest the input signal to be shorted during the testing of the amp which I usually do in all my class A amp builds.
That's not it. Here's a video. Without op-amps all the power is normal, after installing op-amps, we get.
If there was a short circuit, the amplifier would not work without the op-amps. AND NOTHING WOULD BURN OUT WITHOUT THE OP-AMPS.
Just a crude circuit, the amplifier is not stable.
You may have a problem with opamp itself, or a faulty component. Check capacitors first.
Have attached a simulation copy. Look at voltage test point and see if you are near.
Tibi
