Amp Camp Amp - ACA
Zen Mod, one more question.since this aca will be in a diy chassis and always used as a rca input stereo amp, no mono, bridged,etc. can’t I just wire the output as a regular amp . Reason for asking is the preamp that will be used with this amp is inverting so this amp is inverting,when wired as normal amp, so output then will be non inverting, right?
Administrator
Joined 2007
C2 bootstraps the upper FET gate drive voltage and takes that voltage over the 24 volts of the supply when the output positive peaks approach maximum output.
Reduce the value and the amp will clip earlier. The cap has to be large enough to work down to the lowest audio frequencies. So leave it as it is ;)
Hi Everyone :)
I built two kits and I LOVE them... question what is the difference between "mono bridged" vs "mono parallel" my layman's guess is the one runs the signal through both sides (Channels?) of the amp in parallel vs running it through one and then the other ? Or am I missing the concept completely.
Also the wiring for using the amps in bridged mono seems to reflect one thing in the picture but another in the description on the plate what are the right output configs for
The one and only
Joined 2001
There's Stereo, and then parallel, which is what you think it is, then balanced where each
channel is driven by inverted signals from a balanced source, and bridged, where there's
one single-ended input and the other channel is driven by the output of the channel which
got that input. The last works because each channel phase inverts.
Ah that makes sense ill play around I have only tried parallel but not bridged yet... parallel had plenty of power for my speakers though...
Wait whaaaat Nelson Pass himself replied I am honoured :) really enjoyed the experience of building these and the second time I did a much better job... I still need to see if it made an audible difference or just looks much better :p
Hi.I have LXD75-1400SW001 power supply in my stock.Can i use them for 48v ACA amp? What is output power for 48v aca?And what is idle current? I could not find information.(however i have downloaded schematic but could not find replies now.Thanks
Output will be roughly twice what's for normal ACA, around 10W.
That's if you keep idle current the same, 1.4A.
No point increasing it further because you have to observe the dissipation of the Fets.
24 X 1.4 = 33.6W, for each Fet.
A 48V ACA should be about 30W at 8 Ohms, (double the Voltage, 4X the power) but it would need the biggest heat sink allowed by law :redhot:. Check local regulations, or your wife.
Seriously, it would be better to build it without R15 for a bias current of about 1 Amp, then run two channels in parallel to spread the heat out. A 12V zener regulated supply for Q4, the JFET would be a good idea.
