I can't find it. Do you have an idea which patent it would be? - Meyer Sound - Patents
Maybe it wasn't a patent, because it was cited as prior art in my patent as "Meyer Sound Laboratories Specification Document for Model UPA-1A" Whatever that is. Hope you can find it.
Yea, that's it. The technical document described the use of foam in the throat. You can see it in that picture. Apparently not worth patenting!?
Has anybody tried to use VACS to display the measured data?
I can't really get it to show what I want....
When I import my raw .wav impulse responses and specify the angle offsets in order to create a polar it seems like the on axis measurement has a lower amplitude than the off axis ones. As if it interprets the amplitude data the other way around.
Make sure the WAV files are not normalized on export. In REW, there's a checkbox in the export dialog: "Normalize samples to peak value".
I think it's something to do with the units.
VACS expects sound pressure, and is getting dBFS
Iirc, the foam was to keep insects out of the CD due to use in outside environments.
So I plotted the fft of the impulse responses from HolmImpulse in Matlab and it seems like HolmImpulse is normalizing, or perhaps I'm missing something'
EDIT: There is a .info file with every measurement where it is specified how much the data is scaled
Data_Amplitude = 0.0036298722639196415
That's not what the literature claims. There is already a "bug screen" on the drivers.
That is sooooo nice! Good invention Mabat!
On a side note, I just managed to finally import the impulse responses into VACS. Here is a plot of 1" driver on a rectangular horn 370x290mm crossed to a 12" woofer.
I got to figure out how to window properly and find a better place to measure.
The UPA-1A uses/used the MS-1401A compression driver. Go to this link, picture 4: 403 Forbidden
Those drivers are made in-house so technical details on them should be scarce. But I don’t see a bug screen.
Now it's perfect -
so are all driver exits a flat line...? a may stand corrected but to my recollection some drivers if i am not mistaken are designed with a exponential curvature from the phase plug on out, so how does your jig deal with that?
and as i don't have the sim software to analyze it i've wondered what the effect of starting with a short exponential expansion coupled to OS or anything else turns out like.
I wonder if planar drivers (like e.g. Heil AMT) emit a planar wave that would benefit from a nice horn. Or this one Order the GRS PT6825-8 Tweeter - SoundImports that was used in Joseph Crowe's Sabourin horn. I wonder how this would perform with optimal horn (waveguide) expansion. Maybe we need the option for rectangular throat to try out 🙂
I've never seen a driver like that.so are all driver exits a flat line...? a may stand corrected but to my recollection some drivers if i am not mistaken are designed with a exponential curvature from the phase plug on out, so how does your jig deal with that?
I suspect it would beam too much at high frequencies, especially for the bigger throats.and as i don't have the sim software to analyze it i've wondered what the effect of starting with a short exponential expansion coupled to OS or anything else turns out like.
- Acoustic Horn Design – The Easy Way (Ath4)
