Building a Tuthill/Reed 5A Tangential Tracking Pivot Tonearm
Effective length is the distance between the pivot and the stylus.
Offset angle is the angle between the effective length and cantilever.
In every tonearm based on the Thales circle the effective length is the radius of the Thales circle.
For illustration a Linkage model by Carlo. From the viewpoint of force vectors all realizations are the same.
What is the effective length for PT arms?
I still don't have any opinion about it yet. 2wice's view has its merit. In his view, the effective length is a force vector not a geometric parameter. In traditional view about effective length, people pay more attention on its geometric characteristics, not its force vector unless you are dealing with skating. Both factors, force vector and geometry, are combined together for pivot arms. For PT arms, do we really need the concept of effective length, a geometric concept? I don't see the usefulness of effective length. Force vector is enough for understanding the skating force.
Part of an illustration from Tejinder Singh Randhawa's [wiki=article]%[/wiki] in Wireless World (March 1978)
This is wrong. Here is an example of a pivoting tangential tracking tonearm. The effective length increases from the outer groove to the inner groove. This has to be the case for the stylus to remain tangential to the groove on the Thales circle.
Hi Bon,
The effective length of the pivoting tangentially tracking tone arm I have designed, never changes. The stylus/cantilever of any tangentially tracking tone arm is NEVER tangent to the groove!
Sincerely,
Ralf
Hi Bon,
Sincerely,
Ralf
Ralf,
I think Bon meant the PT arm which is similar to my 6B. So does alighiszem. If we include all kinds of PT arms in our discussion, we can’t continue to have a meaningful dialogue. Yes. The groove is a spiral. Even it is a spiral, I don't see the reason why the stylus can't be tangent to the groove. However, it is beyond the topic of this thread.
Let’s examine alighszem’s statement.
Please see the diagram. The radius for the Thales circle is XY while the diameter is XZ. The blue line is arm effective length( let’s assume it is the effective length for now in order to carry on this discussion). Obviously, his statement is incorrect. The effective length is neither the radius of the Thales circle nor the diameter of the Thales circle.
As I suggested early, let’s forget the geometric concept, effective length. For the purpose of analyzing skating force, all we need are force vectors, and the interactions of all the force vectors.
Hi Bon,
Sincerely,
Ralf
Hi Ralf.
You may have answered my questions in previous threads and if so, maybe you can put links to the discussion.
Is your tonearm servo controlled or passive?
I realise my language may have been slightly imprecise.
Discounting the infinitesimal discrepancies caused by tracking a spiral with finite pitch rather than a locked perfectly circular groove, off centred discs, or cantilever displacement by sidethrust, do you accept a tonearm whose straight armtube is tangential to the locked groove, as tangentially tracking or not?
If not, what is your criterion for tangential tracking? It seems sensible to agree on the definition of tangential tracking to have a meaningful discussion.
Bon
Hi Bon,
First I would like to assure super10018 that I am not trying to hi-jack his thread.
The tone arm I mentioned, is propelled across the LP by the frictional pulling force of the rotating LP. The inward force resulting from the off-set head shell is opposed electronically. To my way of thinking, that is not servo control.
If the center line of said straight arm tube, the center line of the cantilever and the center line of the pivot for horizontal rotation occupy the same vertical plane, and where the stylus is engaged in said 'locked groove" then yes, that tone arm would be tangentially tracking.
Any reference to tangential tracking should refer to a "concentric circle of random diameter between the limits of the start and the end of the modulated groove" I know it is a mouth full but it is a fact.
Sincerely,
Ralf
"The tone arm I mentioned, is propelled across the LP by the frictional pulling force of the rotating LP. The inward force resulting from the off-set head shell is opposed electronically. To my way of thinking, that is not servo control."
Is this a sort of electronic antiskating? What are the input parameters?
"Any reference to tangential tracking should refer to a "concentric circle of random diameter between the limits of the start and the end of the modulated groove" I know it is a mouth full but it is a fact."
This is sort of overkill. The manufacturing precision of cartridges is not as good.
"One day I asked a cartridge manufacturer friend of mine, “What is the average error?” After a little pause he said, “Degrees, three or four? Or ten?! It all depends!”
Manufacturers cannot easily keep the necessary precision under control. Some of them even accept that the product will vary in quality and select their cartridges from good to bad and price them accordingly. You always buy the same basic cartridge, but the better they are the more expensive. This is usual practice in the business."
I am trying to improve the base since I learnt that leveling is critical for PT arms. The mounting function and leveling function was not independent from each other. Now, they are independent.
Hi Ralf.
Hear, hear. I welcome respectful debate on the means to achieve an objective as distinct from attempting to undermine the objective by introducing non sequiturs.
I agree completely with your definition of tangential tracking.
Bon
PTT Skate
attachment.php
SFx3
I did the simulation slightly different, the mechanism is seized, this allows the velocity to represent the SF at a single point instead of a range in translation as in the previous simulation. 2nd pivot is lifted, so we can see the velocity instead of reading a reaction force in numbers. The magnitude of the velocity is directly proportional to the SF at that position. Obviously exaggerated, there is no mass, so no inertia or friction for damping.
Green - Red - Blue
You can deduce that the SF reduces towards the spindle fairly constantly, it is nearly linear, my previous calculation showed a slight increase in the rate of change, but it was not much. Very similar to Al's calculations but with a little bow downwards at the end, might just be a scaling issue on the axes.
I did note something in the Geometry, if the distance between the fixed pivots is increased by 0.7mm the sum of the adjacent sides is equal to the sum of the opposing sides, so I did that. It does not change the outcome.
Not sure if it is of any interest.
