747-IXFP36N60X3
Mouser has IXYS 747-IXFP36N60X3
I see the Vgs th - Gate-Source Threshold Voltage:5 V
The :Infineon Technologies IPP60R022S7XKSA1 Vgs th - Gate-Source Threshold Voltage: 4.5 V
Will this part work?
Thank You
Thank You
Thanks much X!
Pete
Pete
These are $3.79 and good for 11 A.
SPP11N60C3XKSA1 Infineon Technologies | Mouser
This has 0.35ohm RDson so will heat up somewhat. Probably will need a small heatsink vs RDson 0.025 ohm ones.
You can search for “TO-220-3 MOSFET low RDson”
I am actually using TO-247 with pins bent to fit TO-220. The key is voltage able to handle mains, so 250v to 450v and low RDson. Also handle the DC current of interest.
It hasn't been tested so use at your own risk. The differences between the TLP3905 and 3906, as I understand it, is that the 3906 has circuitry for more rapid turnoff. I expect that it will work just fine in this application.
Hi Turion,
Good find there on TLP3905 - I think it should be fine. Looks like 100 or available now and 1000 by December.
Thanks J & X! I've got the "06“ on b/o but I have the “05“ in the circuit now. I'll be cautious..
Pete
Pete
And if you connect one of them reversed (it happens) you will instantly blow a fuse if you have one installed. 🙂
That's good to know...
P
Hi all,
Had to sand the board ~0.5mm on the side to make it fit within my case; is there a performance/safety risk with the LV ground connected to chassis? Main concern I believe would be noise from the toroid coupling to the LV gnd?
I'm planning on adding electrical tape to cover the LV ground, but wanted to confirm for other contact points (bolts, etc)
The diagram I have says 84x88mmXrk, great looking board as usual. What are the dimensions of the pcb?
Merry Christmas all,
Pete
Anyone have a substitute for the LM2903 comparator?
Not in stock at Mouser or Digikey.
Randy
Randy
My bad, I didn't try adding these parts to Mouser until today.I should have sent some of those along with the TLP’s that went out yesterday.
I'll look for an alternate
Randy
https://octopart.com/search?q=LM2903P¤cy=USD&specs=0
Looks like LCSC (whatever that is) has them in stock with 1pc min order qty. It says TI does too, but I'm not sure if I believe that TI will sell you 1pc direct. Worth checking though
- Group Buys
- Soft as a Feather Pillow (SFP) SSR Soft Start Circuit GB
