Krell KSA 50 PCB
Hi, may be someone can help me out.
I have manage to get to pinkmouse boards working quite nice. But I'm having a strange problem that i can't figure it out.
As long as i have the input signal and ground shorted my amp stays stable with 250mV bias voltage over 0,47Ohm emmiter resistors. But as soon as I unshort the input signal and connect a dummy load or a speaker my ground starts to drift and i end up with a -72V rail and no middle ground (my posite railt end with ground potencial).
The strange thing is that is happening to both of the boards that I have build.
this is the PS configuration that I'm using
Please much appreciate if some one can help my out
Thanks Octavio
You have an issue with your Power GND I would think at first. EDIT: What he ^ said. Should have refreshed my page :)
does any one have gerbers for any boards discussed in this thread?
I have gone through messages since 2005, but only found eagle files and I am not experienced enough to convert them.
EDIT- There was one gerber file as well but when I try to upload it to JLPCB it does not populate the size, if it is correct file then please tell me how to bypass this size issue?
Many Thanks
  • Krell_KSA-50_Gerber_Files.zip
Hello everyone . Sorry if I ask questions that you have already answered but it is really a lot to read everything. I also bought the pcb from ebay clone mkII. I would ask if the values ​​printed on the pcb are ok to realize? thanks
Ask the seller on eBay that you bought the PCB from to send you the schematic from which the seller created the PCB layout from. We can't help you with that as there are various KSA50 variations, and we do not know which one the seller used.
it's this one pcb
Pinkmouse used eagle to do his boards. Then he sent me the files and I had the boards produced through a company.in Canada. They were 2 oz copper and came out really nice. I built a half dozen klones for friends and never had issues with them.and all are still in.use. I likely have the same file sitting here as well. The KSA-100 boards were done by a chap in South Africa and I had the boards done the same way.
I am actually thinking about a water cooled KSA-50. All the 50's I built (8) were forced air. There was one driver board before Pinkmouse did his and it worked ok, but had a couple of errors that had to be jumped before hand. It was also a PIA to mount the drivers... but it worked out well once I soldered them to the back of the board. That amp is still in use by a friend today.
Mark
