Improving SLAPS - introducing X-SLAPS
A while back, I stumbled upon the ZF or Zeus amp doe to working on an inductive volume control project. Circlomanen tested the ZF many years ago and I was curious if he used that amplifier still.
He mentioned the SLAP(s) amplifiers and this is the first thread out of 4, that I have read through - very interesting amplifier.
Just one question: Looking at the sch. there is only 1 Vinput, but the design is balanced. Is the 1 pcs Vinput a simulation thing and in reality one uses bot +V and -V for true balanced operation ?
Yes, X-SLAPS is very interesting and unconventional and kind of the "end station" for the SLAPS technology - until Circlomanen comes up with a new bright idea!
Vin is just a label. The real input is V2, and V2+ and V2- are used for true balanced operation just as you suspected.
I got a suggestion to use a cathodyn (a.k.a split load inverter).
But I cowardly walked away from that path.
The preamplifier is now a simple operational amplifier (OPA1612) with 11 times amplification (V2+) followed by an inverter (V2-).
I will exhibit the X-SLAPS together with SALS?A! in November at the diy meeting in Mölnlycke.
Thanks for the reply. If it were up to me, all amplifiers used balanced operation 🙂
Since I am working on a passive transformer based pre-amplifier, if the X-SLAPS need gain, then the gain stage need to be in the X-SLAPS itself. Perhaps a 1:11 step up transformer 🙂
A diy meet in Mölnlycke sounds interesting, if I can attend, I would be able to gaze upon your creation, share some thoughts and learn first hand from the creator 🙂 - I will check the thread you linked to.
Many thanks
Yes, that's a thought. Alas, I lack the knowledge on how to make a good one.
And, as the pre-amplifiers I have are in the same domain as the amplifiers in the DAC, I hesitate to introduce a signal level transformer as yet a domain.
Many thanks
Otherwise, you are of course welcome to visit me at my "shop" anytime. I live in Hyssna, 40 km southeast of Göteborg.
I think it's best if the source is always at full line level output and then adjust the volume with an inductive volume control which is a constant power device opposite to resistors which are power converting and throw input away as heat,
in order to attenuate the the output - The results are less voltage AND current. To me, that is a form of compression.
The inductive type does not do that. As we attenuate the volume, the voltage goes down and the current as well as inductance goes up. The dynamics and micro-details are said to be very high for TVC based volume attenuation. 😀
A private introduction and possible listening session - tumanhand - I would not mind that at all - expect a PM 🙂
Thank you Zen Mod and ItsAllInMyHead.
Yes, it has been an intense summer.
By the way, when I was talking about putting them in the cupboards behind me, I meant hiding behind me.
The cupboards are actually in the attic as it is a sloping roof, so their dissipating heat will not disturb me and they will have it cooler.
And my listening room will be less cramped.
I've just passed link to my close friend, living in Gothenburg
who knows, maybe he'll be interested ........ not exactly DIY person, but his entire amplification is made by me...... it counts in some way 🙂
That would be great!
If he decides to come, I'll be more than happy to play some amplifier shot out music of his. I'll PM you my mail address so that he can tell me.
I want to try balanced XSLAPS;
The calculation for single 23mH inductor as flollows;
For bifilar winding we have to double the values here above;
I was thinking if quadrifilar make sense or not?
Also in both bifilar and quadrilar winding there is 2 pin end output but we need 4 pin positive rail, negative rail, drain and source.
Could you please make a small sketch to explain it.
