LuFo Amp - 39w SE Class A from 28v Rail
Hi Zman01,
Yes, this will be similar to how we did the OPA454 with the DC/DC boost on the sub-mezzanine level and the preamp on top. Here is the render - I guess I forgot to post it previously.
attachment.php
Once stacked it would sort of look like this except we have the coupling cap on the bottom sub mezzanine board:
962412d1624593694-opa454-front-lufo-amp-b543d4c7-ca91-470c-b157-e4a4c1d9598b-jpeg
Hi Zman01,
Just to be clear, the idea is to house these in the amp chassis and have them act as a voltage gain stage, rather than use them as a separate preamp?
Yes, they are designed to go right into the LuFo main PCB, like this:
966241d1625992711-lufo-amp-39w-se-class-28v-rail-lufo-build-part1-01-jpg
However, since they follow a standard format of the M2X bolt pattern, you could mount them in an M2X amp. Or in an external “breakout” experimenters board or an external preamp main board shown elsewhere.
If you look on Post 1, I show an ACP+ preamp in this format mounted on a breakout board.
954042d1621739943-lufo-amp-39w-se-class-28v-rail-lufo-build-04-jpg
This lets you connect power supply and audio input and output.
The special thing about these double stack front end boards is that they have a built in ultra quiet DCDC booster that takes the standard PSU rail and converts it to the +55v needed to drive the front end to 50Vpp output swing needed for 39w operation.
Sounds like ZM's bread and butter, X. More IRON!!!! 😀
How much output can you get from that side of the transformer? Still 39W?
I tried something interesting. I connected the free winding to a speaker and it sounded great! Basically a transformer output coupled SE Class A amp with choke load. Maybe sort of like the Zeus but running full Class A. I guess one avoids the output coupling cap this way too.
When you leave the secondary ungrounded you will have a (floating) balanced output.
I am more interested in the winding ratio (easy to measure); likely primary to secondary will be a step down. We are talking about a MOT, right? No idea about winding ratios of those.
When for example the ratio is 3 : 1, instead of the loudspeaker impedance (4 or 8 ohm) the amp will see a load of 4 or 8 times 9 (winding ratio squared) = 36 resp. 72 ohm.
That will cost output power, but be beneficial for distortion.
At the same time DC current can be a factor 3 lower; max output power will drop from 39W to a little over 4W...
In other words, when using an step down output transformer, you must redesign the amplifier (power supply voltage; DC current...)
I might be wrong.
But the LTSpice model for LU1014D used in Post #1 might be problematic.
I couldn't get the wished Id-Vds curve with the model.
