TPA3255 - all about DIY, Discussion, Design etc
Do you have another PS you can run the amp with then test DC offset again? I'm making the assumption that you have a single SMPS (providing "+" and "Gnd (return)" voltage connections to a single amp board (dual channel)?
The issue exists even if the source is not connected. What could be the issue and is there any solution which I can try. Thank you all for your suggestions. Now I learned how to check DC offset on amplifiers.
[emoji23] any suggestions if I can rectify the dc offset other than sending the amp back to China.
The DC offset cannot come from the source because the inputs of TPA3255 has series input coupling caps. So check for the input caps themselves, they might be shot already so they cannot block DC anymore (coming from 1/2 opamp supply), change the broken input channel with 4.7uF polypropylene or 10uF electro caps..
Also check for the output filter (inductor + cap).
BTL imbalance (DC offset) trigger of TPA3255 is 1.5A, so if you are using 4ohms speakers, the DC protection of TPA3255 should trigger.
  • JLE SYLPH-D200 power vs frequency vs distortion into 4 ohm Measurements TPA3255 STEREO amplifi...png
"I am happy to recommend the JLE Sylph-D200 amplifier module" of the panther.
Hello
Well done, great achievement.
I had no doubts about the "I am happy to recommend the JLE Sylph-D200 amplifier module" of the panther.
My V1, has been on trial since November (about 16 hours per day) and I am currently putting it in a box.
I partition the different modules as much as possible, it is a lot of machining.
I chose to deport the input and TPA input capacitors.
I use big Wima mkp10.
Another big thumbs up!
Best regards
Roger
Good Job Jlester )
Your module works great for me.
I am pretty surprised about the power @ 8 ohms / 35W for both channels.
It remains light but sufficient for listening in a non-oversized room
So you can compare :
The A07 TPA3255 @48V / 3A will provide you 61W / 8R
VS @32V / 5A = 48W / 8R
Hello
Best regards
Roger
Thanks Roger!
Good Job Jlester )
Hi Daniel,
We identified that the early clipping was due to overloading of the input of PFFB.
Since your amp has unity gain buffers, it should get the appropriate power output. You can check by measuring voltage before clipping light indicator lights up.
Lester
