Acoustic Horn Design – The Easy Way (Ath4)
Tried to employ the "no overhangs" print method to a rectangular waveguide (280 x 242 x 90 mm) - on Chiron, at 0.8 mm nozzle/0.4 mm layer the estimate is ~20 hours, which is still acceptable. And this is not fully optimized yet, it could grow in something like fractal manner. I seriously consider giving it a try.
Printing it face-down with supports, the time estimate is roughly the same and the waveguide body is much thiner. I guess it would be a nightmare to remove all of the supports (maybe not, I don't know, but my experience with supports hasn't been always good).
Oops, the above was for 30 kHz. This is more realistic, 10 kHz -
(It seems there's a slight reflection back when the wave leaves the screen area, so this clean wavefront pattern gets disturbed. I don't think it's correct but it's probably difficult to overcome this completely in a finite simulation, I don't know.)
Edit: Hmm, this can't be 10 kHz, based on the wavelengths shown. Is there a bug in the ripple tank?
I have two questions, maybe to both you Marcel and also Mr. Geddes:
1) What trade-offs do you see between a rectangular waveguide with high-frequency dispersion slots like Tritonia/M2-style and an axisymmetric OS-SE waveguide?
A note aside: I began to work with a well known cheap JBL-waveguide, but was pointed at issues that narrow vertical dispersion introduces to DI around crossover frequency. See fluids post here, where he brought up kimmonosto's 1.2 lambda rule for DI optimized 2-way vertical spacing. Kimmo repeated his lesson recently over at htguide.com forums. Since then, and also because of further limitations of the current device, I want to replace the waveguide in the long term with a custom solution.
2) Would you have a recommendation, how a non-trained person (studied humanities, not science) can, over the course of some years, acquire the knowledge to design waveguides? Where to start and what could be a reasonable way of learning it for the DIYer? It can take time, does not matter, but it would be beneficial to not only use the Ath software, but really know what is happening.
Marinus
Rippletank has some problems, mainly it has limited resolution and reflection happens per pixel if you raise the brightness, try straight wall and packet source on it, brightness to full. All is fine, until you rotate the wall, now the wall is "pixelated" and million reflections emerge where in real world nothing changed (system was rotated).
Very fascinating but has its limits 🙂 Asked mr Falstadt about it and seemed he has no interest do something about it. The source is available on github and found some other similar WebGL based sources by Googling. Tried to learn it for few hours but the shader programming was something I didn't want to dive into so left it.
Yeah Paul Falstad. Here illustration what I was trying to convey.
Anything but straight line and there is extra reflections happening. Anyway, it is nice to see diffraction and stuff visualized. I tried to study baffle (and enclosure) diffraction stuff with it. The UI is nightmare but luckily the elements can be generated by custom code / UI 🙂
No, actually I have never used Hornresp. Well it took me about half an hour to learn the ripple tank definition format and to code the export function into Ath - I'm pretty self-sufficient 🙂
- So can Hornresp show internal HOMs clearly when driven with a single pulse? That would be something. Falstad's ripple tank doesn't seem to be reliable enough, as tmuikku demonstrated.
