DIY Sony VFET Builders thread
Ready to be populated. 😀
Couldn’t resist a test fit.
Breathing a sigh of relief. Everything fired up great. Just as adason said, I was getting around 15v with pots at half way mark. Adjusted up to 19v and will see what kind of change an hour of warmup brings.
Will listen to it soon, but I have nothing but great things to say about this kit. Well considered and looks incredible 🙂
That looks great!!!
So, for those of us waiting on our kits... the entire input stage is soldered to the filter and to the inputs of the output stage. For those looking into the future to test different input stages, there are no means to make these changes without rethinking a bit connectors?
Thanks for the feedback.
Rafa, that’s a good question. I was considering using 2-position terminal blocks for each of the input, output and power entries. The holes on the input boards were just a little too wide to fit the terminal blocks I had. It’s possible you could bend to make fit or find a wider terminal block(?).
Its actually other way around. It draws more current when you set lower voltage on the source. Set 20, its very stable.
*ALERT*
Please check the silkscreen / polarity orientation of your C1 capacitors in OS. Mine has discrepancy from the one in the documentation and Jim’s (6L6) build. I know this first hand...
