DIYA store "Wolverine" (Son of Badger) .... suggestions ??
Here is the deal ....
The EF3 is proven.
The Wolverine is the simple default amp. I would build it (if it was the only option). If it was not simple , some would not.
Look at the majority of forum designs , the simple ones get built.
Look at Pass , single semi's.
But , to please even a more diverse group .... the open ended nature
of the interface will fill that need. (I want "spooky") 😀 .
OK , FINAL (below) D8 zener/ or R5 option. Q5 GONE.
PCB reflects these changes.
I'm going to do one more check to see if the devices/holes conform to
UMS specs and submit it.
OS
OS
The EF3 is proven.
OS
OS
All good OS,
Thanks for putting forward what you think is best after considering all options. Can you post a sprint layout file to so I can help with the final check?
The EF3 is proven.
OS
OS
Thank you Os,
so this is the final version of wolverine.
what value for R5 (option)?
can I say something? please don't kill me xD
the IPS board holes is a bit off that can be fix is just
micro adjustments I would change the grid to 0.25mm
then I would then make the outline snap to grid after
that is done then I re-adjust the IPS PCB outline to a
solid number is now 120 mm x 50 mm also what is
need it to do is re-adjust all holes of the PCB so they be
exactly 180 degree in Sprint Layout 6 is actually "0" Angle: 0°
one way to do it is be placing a silkscreen circle with a 6.50 mm
diameter close to the edge of the IPS silkscreen then use the
circle as a grid make sure that automatic capture is on,
ok so far after adjust PCB outline to the 0.25 mm grid I
was able to adjusted to 120 mm x 50 mm nice, ok so now
the distance between the holes for the M3 standoff have
a distance of 56.750 mm long side and wide is 43.500 mm
oh yes and you can even go fancy with the rounded corners
too lol I attached the file ST so you guys can see what I mean
edited: is fine the middle hole top 🙂
  • DIYWolverine IPS board.zip
Vargas , only a 1 row SIP on a 3rd party IPS board.
OS
Hi OS.
I was Talking to Harry and he suggested moving the input cap C1 away from the output stage. So I had ago at doing that.
What are your thoughts?
# 1 . I took both your idea and Vargas's and integrated them.
C1 is split for us that use normal input caps and is verticle.
Offset has better access , holes with rings are aligned 55mm apart.
This is IPS standard - we have to get this right.
PS - you triggered me , Stuart ... you check it !!
OS
Not sure but this kind of information is useful to me:
I'm compiling a text with the raw data on the optimal components that I
have based my layout on.
NO special unobtanium devices OR values - all standard ... only about 10
values in the whole amp's 52 resistors.
For example , the D8/R5 option .... https://www.mouser.com/datasheet/2/427/tzxserie-1767901.pdf Very low noise.
Or the "Spooky" IPS red led's - https://www.mouser.com/datasheet/2/678/AV02-1562EN_DS_HLMP-x15x_2018-07-23-1827993.pdf
1.6Vf just like my model...
OS
