^Done. Problem with PRs only due to few missing parameters. Hopefully nothing else won't damage because this required shortening maximum length of value + unit.
Someone could also inform North American retailers such as Parts Express that driver manufacturers (including Dayton) use SI units. Not any moose's heads.
^^Yes , as per schematic.
If using ARTA, click the "dual channel mode"
Thank you. Make sense. I'm familiar with REW afraid
Hello Sergey,
The connection between the speaker terminal and the right channel/right XLR input seems to be missing. That is your loopback connection. Delete that green connection.
Sorry, not get what to do... Confused even more. This card has 2 inputs in front, phantom power, and stereo/mono switch. Can't find an exact way to connect the cables to make everything right.
I think preamp already in Scarlet 2i2 that's why I delete it from schematic
Part two not even get
Hi. Just received the mic. And have some confusion.
Can you tell me which way to connect it correctly with the interface, please?
Do I need to loop one channel according to the schematic?
Joined 2003
This is not really a topic for VituixCAD thread.
Please read ARTA manual starting at page 8 "1.2 Measurement Setup"
https://www.artalabs.hr/download/ARTA-user-manual.pdf
With only a couple more resistors, you can confidently toss the DATS and use your audio interface for all impedance measuring requirements using LIMP. Read LIMP manual starting at page 9 "3. Hardware Setup"
https://www.artalabs.hr/download/LIMP-user-manual.pdf
Yes I know. I just stuck during VituixCAD manual reading.
Can't find ANY good video tutorials how to do it.
Yes I know about DATS you can live without IF you know already how. Not me
Seen manuals b4 and bought a "plug and play" solution.
Next time will be crossover questions only.
Promise
Promise
sorry if this was answered some place already:
I recently started using VituixCAD and started first with an active Xover design. Then I replaced some of the active filters with the passive ones to reduce the number of way. However as far as graphing the calculation results on the right side of the screen everything works but the impedance is not being calculated. How can I have the impedance calculated for the passive portion of the Xover?: All drivers in the model have both the freq response and an impedance curve entered. Thx a lot.
- Design & Build
- Software Tools
- VituixCAD
