Babelfish ᄅſ....or FW J2 on Steroids .... or Not your Father's J2!
Just repeating ZM below. I did not fully follow your build. Just noticed that you have higher rails and don't remember what they were before the new transformers. Mine has 18V secondaries. I don't know if the resistor values in the snip below are correct for your setup. The point being P102 for Iq and P101 for offset; Increase series resistor as appropriate. And readjust pots and measure before power up.
And Denver, CO ? Small world.
P102 is for Iq set, while P101 is for output DC offset chase
if you need more of any, just increase resistor in series with trimpot
for instance, R123 goes to 510R, R118 goes to 1K2
do not forget to go back with trimpot before powering up
everything referring to schm in post #1
Hi BA. Yeah! Small world indeed! Are you in Denver as well?
I did base my resistor changes on that post but Semisouth down has a different starting point for R118. I did my own math there but probably shouldn’t have. 😕
just lloking at my morning coffee
even sight still mushy, let alone brain
so - if you didn't solved it already, please recapitulate, for us little handicapped
("I want that Iq, but now I still have just this Iq and DC Offset is this; resistors are(not) changed")
Good morning ZM! Latest resistor values and measurements in post #499. With a little guidance I’ll give it another try tonight.
Currently:
R118 = 499R
R123 = 510R
Iq max = 775mV - I would like to get to at least 850mV
DC Offset min = 435mV
I realized Semisouth down R118 is only 270R so I swapped for 499R. And R123 I swapped for 510R as prescribed. Didn’t quite work out. I can only get Iq up to about 775mV. Offset won’t go below 435mV with pot maxed out. Doh! Thinking I should put R118 back to 270R and leave R123 at 510R?
just one more detail - at which resistor group you are measuring Iq (as voltage sag)
which figure (in A) you are shooting for?
783109d1569266460-babelfish-fw-j2-steroids-fathers-j2-schm-channel-jpg
Using this schema for Semisouth down with .68/1R resistor groups. Iq measures the same at all source resistors. A little update too. Just remeasured. Iq settles at max 758mV. DC offset is actually -358mV with pot turned all the way in.
BabelJ2 is fully operational. It is a little tricky to really dial in the offset on this one. Bias is 1.8A. Heat sinks on the 5U 400 hold steady just a smidge below 50C. I had an Antek 400va with 22V secondaries but voltage seemed a little too high. Swapped out for 400va with 20V secondaries. The SLB is 23.4V +/-.
And the sound. Ooo the sound. I’ve only tested with my workshop speakers with a cheap Bluetooth receiver as the source. Dayton PS95-8 is karlson foamcore enclosures. So far this amp has phenomenal imaging. Listened to A few tracks from Roger Waters, Amused to Death. I have never heard a soundstage like that. I didn’t know it was possible. Also, Eric Clapton Unplugged. Very nice. Can’t wait to get this into my main system with a real pre-amp. Will report back again soon. Here are some photos of the final product. Glad I really took my time with the wiring on this one. Those BabelJ2 boards really deserve it. Thank you ZM! I had the prescribed 270R in Rx18’s but I couldn’t adjust offset enough. Paralleled the 499 with 1.05k because I got a little lazy to look for any 330R in my parts stash and I didn’t want to risk lifting any pads on desoldering those again. Worked out well in the end. 😀
Then don't put two perfectly spaced holes in your PCB's ZM!!! Haha!!! :rofl:
I hear you though. El cheapo fast-ons almost fried my whole build. I spent a few more cents and bought some legit locking fast-ons from Mouser. All are crimped and soldered and they have a very positive connection to the tabs. That said I may go back and solder wires straight to the board at some point. I still have to see if this wiring layout is the best with high sensitivity speakers. Hooking up to Lii-Audio Crystal 10's very soon.
Thanks for the complements ItsAllInMyHead. I had to go back and read your posts on your build and impressions. Are you still using the Iron Pre with yours? The BabelJ2 is up to some stiff competition against my F7 clone paired with a WHAMMY pre. I recently swapped the LM833 for a Burn Brown OPA2134 in the WHAMMY. Less DC offset and a little more detail. I will try it with the J2 and compare vs F7.
