B1 Buffer Preamp
any drawback in building a dual supplied version?
Not really, but what is the point?
Some people are obsessed with bipolar supplies and no caps in the signal path, especially electro ones.
I am not one of them.
I like the simplicity of single polarity PSUs for amps and preamps. To me they are easy to understand, easy to implement, logical.
If you like they are more Zen than the bipolar versions.
If tube circuits historically use single polarity supplies and we all rave about their sound quality, there is no reason why we should not use the same approach to transistor circuits.
Single ended amplification is simplicity in itself so why complicate things?
Maybe build both versions and listen, then you can decide for yourself.
Thanks for your feedback, the answer to your two questions is in the part you deleted when quoting me: I would use this buffer in a rack system that already has a stabilized dual supply. On top of that, having many I/Os, no coupling caps would mean a cheaper system as well.
Well, there you go.
You answered your previous question nicely...
You obviously already made the decision to use bipolar supplies, so my previous rumblings were redundant.
Thanks Andersonix, I will read those threads tonight.
Thanks Stanislav, no decisions made yet, just an opportunity and I asked to you more experienced people about this circuit if that application could have been possible.
Andersonix raised a good point indeed.
I have ran a few sine waves through the B1 now. Everything looks normal to me. However, sound is still terrible. I am connecting it to a Moon DAC and two Amp Camp Mono blocks. I just cannot get what the problem is....
Hi - no the 1,27 volts is the output from the B1 - the yellow signal is generated by my computer and measured at the input to the B1.
Sound is clearly distorted, overdrive is not unlikely. Not "sweet and creamy", rather sharp and not agreeable. I agree on the difference between pos and neg. I will do some new measures tonight and post them - anything in particular I should focus on?
I did some new measures - no DC on output. Also did some new sine measures with the scope. Everything looks fine until I measure after the JFets - then the negativ sving differs from the positive. When I measure the DCvoltage across the JFets Q100 and Q200, I noticed something strange: the gate has 1/2 the supply voltage as expected, but the source is the same as the supply - isn't the source supposed to be half the supply?
