Salas SSLV1.3 UltraBiB shunt regulator
Hi Salas!
I get problem, the Led just dim with weak light, and I can not adjust output. Pls check the picture bellow and help me to fix it.
Thanks a lot !
Hi Salas!
Thanks a lot !
To understand better, you made boards of your own and positive works but negative does not? If yes, and you are confident about parts orientations, see if Q2 Q3 have good Vbe about 0.6V. If yes, next see if M1 has good Vgs 4-6V, M2 good 3-4V. Last if there is oscillation on the output. Takes a scope for that.
Hello Salas,
I need to ask something. I'm planning to use UltraBiB for a 8V/35-50mA load. Input voltage will be 12V DC preregulated -LM7812- directly on the current limiter resistor -no rectifiers, no C1. First question is if there is anything wrong with that? The next question is how to trim the current limiter in order to minimize or even eliminate heatsink?
