Beast with 1000 JFETs redux?
Third iteration of massive complementary buffer. 80 buffer pairs for headphone usage and flea power speakers.
6-layer board allows no hand routing between buffers. I only had to route one buffer and clone the rest. The cloning plugin also can arrange a matrix of identical circuits.
All of the circuit nodes have their own copper layer.
To me this is the most interesting. It has a lot of good things:
Available jfets
Hand soldered
Cheap and easy
Good looking
Headphone/mini amp/preamp all in one.
No feedback
I have several 12v 4amp transformers. I'm tempted to try it :D.
I think the "full blown" power amps are the most interesting.
The TO-92 version gives a bit freedom to e.g. match the devices if this can enhance performance. The smd version makes it a bit easier to just purchase a number of mounted and tested boards?
Think it also depends on how they each performs when a prototype is tested?
80 buffer pairs for headphones or supersensitive speakers.
BR,
Ernst
Yes to all of that. The SMT version will be a massive B1 instead of a complementary buffer as in the original Beast with a thousand JFETs by Mr. Pass. I cannot find any complements that have reasonably low Rds_on. All of the P JFETs in SMT that I can find have Rds_on 4X greater than the 2SK2145 N JFET by Toshiba.
I have the first 4 layer boards in hand. Checking the cross-talk before installing any Rs or Qs.
6-layer board is out for production. 3-D rendering of the 6-layer board is attached. The final board has some silk screen layer improvements.
As noted, Nelson is exploring different “beast” topologies. The picture below is one of his micro-beast topologies: 48 parallel cells, each cell consisting of a J113 jfet follower with a J113 jfet CCS. The poor design is purely my fault.
The micro-beast makes a wonder headphone amplifier. The 32 ohm output impedance drives my Final Audio D8000 headphones and even my Abyss 1266 TC. The micro-beast sounds as good in one minute as is one hour.
As expected, the single-ended topology yields a 2nd harmonic output. I’m running it with +- 12 vdc. Since it is a follower, voltage is not critical as long there is a volts of headroom. Each side draws 1.6 amps.i
Joined 2019
Very cool. Nice seeing the J113’s in play.
Sweet. Nice to see a close up of the master's design.
I have looked at the J113. The 2SK2145 is much more appealing to me as the Rdson is lower. I came up with a figure of merit where gm is at least Idss. As an example, if Idss is 8mA, gm is at least 8 milli- siemens. For the 2SK170 , gm is much larger than Idss. For the J113, I remember that gm is much less than Idss. That is just from memory.
The J113 was not intended to be the best choice for a micro-beast. Nelson has thousands of J113s, and they are cheap. With careful matching of the jfets the micro-beast has a DC offset of 2 mV. Nelson doesn't do surface mount parts.
The Toshiba 2SK2145 is an attractive part. Zen Mod uses them in the buffer section of his Iron Pumpkin, a brilliant sounding design. If I understand correctly, the Iron Pumpkin preamp uses two strategies to handle the DC offset problem. First, matching the 2sk2145s. Matching requires a special jig to measure the jfet. Second, adjusting the supply voltages to achieve low DC offset. Zen Mod suggested that his buffer design would make a good front for a micro-beast. Also Iron Pumpkin buffer's low output impedance will help drive the collective gate capacitance of paralleled jfets.
What poor design you refers to? It's magnificent!! I like even the brass handle :)
Which Jfets will you be evaluating in the 80 buffer pairs version? I'd be really interested in that design for headphone use.
Look at post #56. I have enough of these for a balanced stereo pair.
I acquired the parts at Arrow and Rochester Electronics.
The pinout of the JFETs I chose are the same as LSK170/J74. You could use the Linear Systems parts. Kind of spendy.
