DAC AD1862: Almost THT, I2S input, NOS, R-2R
Shunt regulators
Did someone listening test between any series voltage regulator and a voltage shunt regulator? (on any R-2R DAC).
There are plenty modifications of Salas shunt regulator. Since it's a shunt, I wouldn't want any active element in the series, so I slightly simplified one from 2009 and put 2 in a row. It holds the voltage under any load. The mirror version for the negative will be similar.
The main drawback of shunt regulator is the large power losses, in my case 20W 😡
No real test was performed by me, maybe it's not even stable.
Whether it makes sense to try ... :rofl:
+1
I've got one on the way for my AD1862 project.
I'm going out on a limb with my project. I have some PCBs in transit that 'borrow' Miro's DAC section layout but I've omitted the shift registers and I'm replacing the output stage and will be using a Borbely tube/mosfet 'op-amp' circuit instead. My DAC section will stack directly onto the I2overUSB, which will obviously be configured to interface directly with the AD1862 devices. Could be a nice little new Year project.
