Wayne's BA 2018 linestage
I'm in the middle of building a balanced version, I used all the values from the schematic with no changes.
When I first tried wiring the inputs with the ground jumped to IN - or IN +, I had very low gain.
With the inputs wired without using the ground pin on the PC board, gain improved, with a slight hum. Still not happy with the sound and gain.
Not sure if the hum is related, I was going to work on that tomorrow.
First try the boards in single ended configuration with a SE stereo source see if they work fine without hum.
Not sure what configuration you are using.
Some people on this board they use 2 stereo boards to make a fully balanced version of the preamp. It means balanced input balanced output. In that case you don't need to change those values. You just use 2 single ended boards with a common ground. One for IN- one for IN+.
If you use a single stereo board with balanced input and SE output, then you need to change those resistors.
There are two different things and people on this thread are confused.
I have two boards I built for balanced operation. Where XLR Pin 1 = ground, Pin 2 =IN +, Pin 3 = IN -.
On each channel the inputs are wired:
IN + to pin 2, IN - to pin 1
The other side is IN + to pin 1, IN - to pin 3.
Gain is poor, just not as poor as when I had the ground jumped to IN + and IN - respective.
I still think both sides of the schematic should be symmetrical with the change in resistor values like you suggest. If not, won't the gain be different IN + to IN -?
Yes XLR pin 1 goes to chassis ground. Pin 1 of XLR is for shielding only, doesn't carry any return signal. You can experiment by connect it to preamp GND sometimes works better.
And yes both IN- of the preamps are connected to PS ground. First make ground connection between both sides then a wire from this connection to PS ground.
BA 2018 Balanced and SE
Apart from all the soldering sagas mentioned above, the BA18 boards that did work I have used to make a balanced pre and a balanced to SE converter. The former uses both sides of a Stereo board for each channel with XLR Pin 2 input to + input , with -input jumpered to ground, pin 3 XLR input to + input on the other channel. The board grounds are jumpered together on the board and all grounds connected to a single point on the chassis including PS ground. Outputs from the + out of each board are connected to XLR pins 2 and 3 respectively of each output XLR. This works fine with the original resistor values and using a VRDN wallwart version there seems to be no hum that makes it past my tinnitus
For the Balanced to SE converter I used a stereo board with the changed resistor values, pin 2 XLR input to +input on the board, pin 3 input to - input on the same channel, output from the board to RCA socket. Grounds same as above . This board uses a Silent switcher to make a very compact and useful unit
In both cases I can use pots or stepped attenuators for volume control, with two pots for combined volume / balance if needed. I am thinking of building the Bal/SE converter into my Passdiy M2x and F6 amps to provide XLR inputs compatible with the DAC I use as well as some Integrated amp functionality
I just bought two sets to make a balanced in balanced out preamp. Good to see the recent exchange that give me helpful hints!
Questions:
1. Can I use KSA1381/KSC3503 instead of A1220/C2690 and should I use the same component changes?
2. If I have +/- 12V regulated supply in the chassis I have for it, would that work?
Thanks in advance!
I think this is a weak point... I have a 10k TKD and it has way to low R, but more than that; I connected direct before I found this TKD in the bin. I dropped the TKD in and I noticed, it took a moment, and replaying a few songs, but yes, there was a definite change.
I like this one enough to look at other options for controlling the input levels.
@Z Does the 50k give you smooth transitions?
@My thanks.🙂
