Slewmaster - CFA vs. VFA "Rumble"
hi Thimios is 125mm x 300mm I just posted here just in case I might lose the file or anything can happen, I spend many hours on this and here is a best save place if I need it is here on diyaudio.com 🙂
hello friend, would you have the gerber of this board with 5 pairs? can I use NJW21193 / NJW21194 transistors IN THE PLACE OF MJL / IRFP?
ola amigo, teria o gerber dessa placa com 5 pares? eu posso usar os transistores NJW21193/NJW21194 NO LUGAR DO MJL/IRFP?
hi this is the original files that provide JKuteman and yes you can use those power transistors 🙂
  • SlewMaster 5P OPS.zip
I would not use those power transistors. If you search back through the thread you will see where I tried to use MJL21193/21194 resistors. For some reason the slower transistors don't play nice in this EF3 circuit.
