Hi valery and jwilhelm,
I made a simple grafik with your advice. Is this right now?
Wat is the background of the RC-Filter, is it against HF-oscillation?
Hi Chris,
A somewhat messy drawing but seens to be correct
The function of a simple RC filter at the output of the servo is to suppress possible HF noise coming from the opamp's output. It normally makes subtle difference (if any), but assuming the servo input is connected to the feedback summing point - directly interacting with the signal - it's better to have it thereb
Valery
Hi vargas,I'm not expert PCB designer but the Greenamp I made it just like the schematic said and I didn't have any problems at all I got the gerber files if you want it to try out the sounds is really good
they are two options of LED regular ones or SMD LED
I'am on the way to design my own layout, more compact, with SMD but also THT. Goal is to put the IPS on a 50mmx100mm Board. The CFA is almost finished. But I get inspired of your board. The next one will be the greanamp. So I'am able to compare VFA/CFA. The IPS is connected to the OPS by a pin header. Similar to Valerys NS board, but my board is fixed in 90° and not parallel. I use KiCad for design - because it is open source. Hope my plan will lead to a functioning Amp .
@Valery: Thanks for the explanation - i like to understand the things and you and jwilhelm are helpful for me.
awesome Ampi oh with pin headers? cool of course is gonna work just take your time and do re-check over and over what I do I play American 80's music and look at the layout and schematic till I don't see any bugs so far works well for me but I also learn to identified all components on Sprint Layout 6 and that does help a lot ok bro good luck with your project
Thank you!
Thank you so much for these hardworks OS! This is really helpful for me for playing around with various circuits and amp topology.
Here is a gift to everyone. ALL the slewmasters.
.lay for sprint , some of the IPS coppers , prints.
With sprint 6 , spooky V1.2 can be sent to a printer.
Download Sprint-Layout 6.0
One zip is ALL the simulations + models.
The second is ALL the layout files for OPS/IPS.
OS
I think it depends, a single one 800VA or more VA's I do not know any toroidal transformer online store but this one Antek AN-8445 - 800VA 45V Transformer - AnTek Products Corp
- Slewmaster - CFA vs. VFA "Rumble"
