First cycle distortion - Graham, what is that?
Se how there's no way around actual measurements to proof a theory, otherwise it's just a thought experiment and of no real value to people developing circuits to sound better and verifying their improvements.
You need to be aware that there are internet shills for audio business. They devised series of internet talks that are geared towards supporting the boutique audio electronics market. Many of them are pro at it and they've invested a lot of time crafting word salad to make it look "delicious".
Since music is very little sine waves or complexes of sine waves and more about transient signals with decay (often consisting of something superficially resembling sine waves), "first cycle distortion" seems to be something that effects most of the reproduced music.
Once you move away from traditional NFB amps and start to use Feed Forward Error Correction instead you open up a whole new level of performance. But no steady state measurement of sine waves across a non inductive resistor will show you why.
I agree with you 100%
Look what you can do with sinewaves, what makes you think transients and their decay, or anything else for that matter would be a problem to recreate?
Pure Fourier series animation montage - YouTube
In DC amplifiers, the signal propagation delay time is physically equal to GD.
A DC signal is a continuous constant voltage of null frequency,
As group delay involves phase and frequency, you can't speak of a DC group delay.
What you may think of is a sudden injection of DC voltage at the input of an amplifier. This is a voltage step.
When such a step is applied at an amplifier input, there is a very very very short time delay due to the propagation of the signal in the path before the feedback signal begins to be substracted to the input signal.
We may consider that, during the very very very short time delay, there is no feedback which means that the amplifier is open loop and its error signal is extremely large and fast.
But an audio signal is limited in frequency and never looks like a step voltage so the error signal does not need to be large and fast.
By the way, do not discard this to stay in a real world :
The hearing mechanism has an integration time which seems to be forgotten in the discusion. It is at least 1000 times longer than 25 ns.
forr, you too literally understand the meaning of the expression: "from direct current to ...." Of course, we are talking about alternating current, which is covered by the term "group delay time". But even a frequency of 0.001 Hz is already an alternating signal, not a direct current!
regards
Petr
Differences in the temporal structure of the signal, which have not yet been clearly defined, are significant for the auditory system, and it is from them that it determines live sound or distinguishes one speaker from another.
It is known that for undistorted signal transmission, the group delay time should be with a tenfold margin, that is, it should be constant in magnitude up to a frequency of 200 kHz.
Well, now look at which GVZ schedules meet this requirement.
This is the case in modern prestigious amplifiers - the signal propagation delay time does not exceed 100 ns! It is this value that guarantees the level of rapid distortions that do not negatively affect the sound quality.
The propagation delay time depends of the physical length of the feedback loop path, does'nt it ? Why should it be shorter in modern prestigious amplifiers (usually cumbersome) than in integrated amplifying circuits like a TDA2030 ?
I'm not an expert in this, but what does this mean? Does it mean we wouldn't hear the difference between two signals if the difference in less than 10us, timing wise? Jan
It means that the brain does not analyze the content of the sound when it's less than 10 µs but considers it as a whole. The data of 10 µs may be not exact, but it is certainly more than 1 µs. In usual amplifiers, the propagation delay in the feedback path may be a few ns. If ICC, at 300000 km/s spead, a trip of a 30 cm or 1 ft takes1 ns.
