B1 with Korg Triode
..The noise variety changes depending where the volume is set, with the lowest volume setting having the loudest noise.
The stepped attenuator I have..
At the preamp RCA inputs we find audio signal from source DAC, CD player or audio card etc.
Input RCA center is "hot" (+) wire and another connection in the same RCA is " cold" (-) aka "audio path ground".
This audio GND wire are connected directly to the stepped attenuator ground connection point ,
nothing else , not psu ground yellow green wire.
With a lot of free space inside the enclosure you have many possibilites,
MKP polypropylene 10uF ( in horizontal position under the pcb for example) from Mouser etc.
can be nicer upgrade for ultimate sound quality.
🙂 Have fun
Edit : Cooper colour inside the enclosure are metal foil or just painting ?
Get some metal shielding can quiet noise level
Thanks for all of the reply's.
The copper colour is actually thin copper sheet, that is all grounded to the star ground near the AC power entry.
I generally try and use a single star ground to keep things simple but I'll have to saty I spend my life confused about grounding no matter how much read!
I'm terrible with instruction so I'll do a drawing of how all of the grounds are connected to show the actual setup.
Ok this is how it's wired, simple right 🙂
All thoughts welcome
  • 19-03-06 Korg Attenuator & Layout Model (1).pdf
@ DQ828
Can you compare noise with other 24V psu?
B1 Korg kit chosen the verified special quiet model.
Try experimenting if so wires who are connected to power on-off switch
can be more distanced from Nutube wires..
Air Gap
Please follow 6L6’s B1 Korg Nutube build guide to create an air gap between the Nutube and the PCB.
B1 with Korg Nutube - diyAudio Guides
In my original build, I used the foamed double-sided tape that came with the Korg Nutube. Not sure if this contributed to the microphony, but it sure did ring whenever I turned on the preamp or switched sources.
When I replaced the Nutube with a new one (original was damaged by a lightning strike near my home), I followed 6L6’s build guide and I haven’t had any problems with microphony.
I used the included foam between the NuTube and circuit board and my preamp is absolutely dead quiet. I think there is a huge variation between tubes and it just boils down to the luck of the draw.
.. I will have a play on the weekend.
Power supply inside the chassis can bring transformer mechanical micro vibrations,
pollution with his magnetic field and some heat too.
The kit version external SMPS power supply is a better solution to avoid unwanted noise.
Maybe try how your psu perform outside of the enclosure.
Less noisy ?
Close all air ventilation holes with more copper sheet around.
🙂 Kind regards
I bought the Nutube a couple months ago, but still cant figure out why I hear an increased high pitch noise coming from the right speaker. Seems like a capacitor charging and then discharging, actually I need to disconnect the speaker because the sound gets annoying. Does someone experience something similar before?
I think the new design is smarter. Mine followed the old double side foam tape suggestion. The Nutube is fused to the pcb. It’s like cement. Every vibration is transmitted to the Nutube and the pcb acts like a sail. That air gap looks ideal. I would like to remove my foam tape, not sure how. All is not lost, my Nutube has gotten less sensitive over time.
Less noisy ?
🙂 Kind regards
The more I think about moving the power supply the more I like it, because I'm about to build my son a new amp I might put the PSU in that amp. Any thoughts on the best power plugs to bring the 24v across?
What is achieved by closing the vent holes?
