Build This MoFo!
Ah... This sounds better! The nice part of the design is that you set the bias with the trim pot. If your chokes get too warm for comfort, you can dial back the bias a bit. You really don't need much above 2A for an 8-ohm load.
Two chokes in parallel will reduce both inductance and DCR. May solve the heat problem, but will also reduce the impact of the chokes on the design...
6L6
Moderator
Joined 2010
24V with Hammond 193V. Prasi boards.
Absolutely stunning chassis by member j_thomas. Ill take some better photos soon but this is just too good to wait. :yes:
