50w Single-Ended BAF2015 Schade Enabled
This is my 'current dilemma' if you'll excuse the pun? 😛
I think I've overlooked something because my lower mosfet is acting like a light switch. I raise the bias until it 'turns on'. At that point it's a dead short and the full 3.2 amps flow through the circuit. What puzzles me is the lower mosfet doesn't warm up even one degree. Stone cold.
Dan
you need to start biasing from low Ugs voltage , gradually opening lower mosfet
in a moment where its effective static impedance ( call it that way) is adequate , you'll have same voltage sag across both mosfets
now, Ugs is too high, lower mosfet is too open, so effective impedance is too small, so no voltage sag across it
That does make sense to me. I have to figure out why I cannot achieve that as of yet. Either a flaw in my circuit design or a flaw in my approach.
More later.....................🙂
taht's the problem, most likely - not fine enough management with pot on lab supply
make external rsistive divider :
set lab supply to - say +6V
put one leg of 5K trimpot on +6V , wiper to mosfet biasing , 3rd leg of trimpot to 4K7 resistor , other end of resistor to GND , where neg leg of Lab Supply is also connected
that way you'll have 5K trimpot span between +3V and +6V
Lab Supply is OK for many things, but its setting pot must be impeccable, or you're risking major ookups
Buddy of mine sent one THF to Wakan Tanka, while doing matching work - his new Lab Supply had twitchy voltage pot ......... and he didn't had fuse in drain etc.
luckily - you have there upper half of amp working as current limiter, instead of you being blasted across the room with bigchunkofplastic, which was functional mosfet few moments ago
:rofl:
:rofl:
Will try soon! Many thanks Zen.
Dan 🙂
I sure bit off a lot to chew on. I did my own PCBs for most of the PS and all of the amplifier. I also built my own single chassis out what I thought were large enough heat sinks but small fans may be in my future.
What’s that old saying? What doesn’t kill you makes you stronger? 😉
Well it will make me stronger because it wouldn’t surprise me if the final
edition weigh 100lbs!
A couple of quick pics later today.
Dan
To ground or not to ground? That is the great question?
In the process of getting my multi kilowatt schade ready I'm now testing
my 2sk170/2sj74 buffer I included at the input. As seen in the pic below I have a separate +/-12 supply for powering my buffers. The question that puzzles me is should I tie the ground of my buffer supply to the ground of my main amplifier supply? 😕
attachment.php
attachment.php
attachment.php
