Aleph J for Universal Mounting Spec
I read in another thread that R5 disipates about 380mW and should be 0.5W minimum.
Store boards use leads space for 0.5W resistors.
They are 0.25W in BOM Revision D thought..
One is downgraded 0.5W military RN60 and another is regular 0.25W CMF55.
Is R5 1W realy neccesity?
Thank you, ZenMod!
Somehow I like that idea more than expand resistor to RN65 size.
Still look nice.
OTL bias procedure
On the board there is a pot for OTL Bias. What is the procedure for doing this bias? I've searched here but cannot find anything here that is definitive. If this has been discussed, please send a link or how to find it.
Frankly, I'm not sure what this is. I've been in the tube world for 30+ years and am not familiar with OTL Bias. OTL in a tube amps means they don't have output transformers. I'm guessing it isn't the same in solid state.
It's a board from the store and I don't believe there is any mention of R8 in the build guide. Once I'm confident I have everything dialed in, I'll replace pots with resistors. Before doing that I want to make sure the OTL bias is correct. Maybe it doesn't matter but I want to be sure.
certainly
:clown:
I can't resist..
Zen Mod, can you please help.
What does it need to change Zener to series LED's in Aleph scheme?
Is it as simple as change Zener diode with series LED's but in opposite direction?
Should I change any other scheme parts and their values?
I drew this cheme with only Zener changed.
Plan was 4 LEDs in series with about 2.25Vf
Maybe Kingbright WP3A10HD (Red) or WP710A10PGD (Green).
