HF1440 New Ring Compression Driver from Faital Pro.
I've recently got a speaker a local company made me. It has a HF1440 driver in a XR1464C horn crossed at 1kHz over to 4x ScanSpeak 15WU midwoofers. All driven by a Hypex FA253 plate.
Having not heard TAD or other Be compression drivers, I will say that this is the closest I've heard a compression driver come to a good dome tweeter. Especially in terms of top octave performance. I can't seem to detect any material coloration to the sound and generally the transition from the 15WU's is seemless without any discontinuities in the timbre.
The speaker has an apparent point source radiation and is able to achieve an impulse-coherent driver blend over a large area. I'm sure this contributes to the sound character as well.
Nice:up:
I'm gonna receive my horn and throat adapters for hf1440 on thu/fri and can start testing them against Tad:xmasman:.
I've attached a render of the speaker so you can make out how the midwoofs sit there. They are supposed to be resonator loaded, but it eludes me whether they refer to the BR or the slit. Disregard how the tweeter looks as this is an older version of the speaker with a different driver.
As for unwanted resonance... I can't seem to detect any either by ear or mic. My previous speaker was a Neumann KH310 and this killed it in every regard in an AB test. Also it goes extremely loud.
It is true that the HF1440 can go lower, but it's mostly horn limited here. A larger horn would work in a speaker where everything has been blown up proportionally. As in - larger woofer slits, prolly 18WU woofers...
Didn't see the extra horizontal board vertically limiting the drivers.. that will push the resonances up even higher in freq..
Basically as long as the low-pass drops the pressure enough higher in freq. it becomes a non-issue.
Dang, these are ridiculously expensive. The JBL D2430K is $599 and you can get used D2415Ks for $599 a pair:
I also wonder why this is so. Faital Prices at P.E. are usually quite competitive compared to European dealers.
But I don't know how well the D2 fares at its lower end compared to the HF1440. Some say that the 800Hz where it is crossed in the M2 would be quite stressful for it already.
Charles
If you need to go down only as far as 700 or 800Hz, why not look at either the Radian 745 or the Eminence 314X. Either one can do that with ease and the Radian is under $250 (if you go for the non NEO model). Even the Textreme diaphragmed Eminence is under $350.
