"WHAMMY" Pass DIY headphone amp guide
New try on mostly SMD Whammy.
First testrun finished successfully.
No burning components till now 🙂
Final wiring required to test the sound.
No OP amp rolling possible I have settled on AR823.
Hopefully this was not a mistake.
Testet in my old Whammy with OPA 2604 but wasn`t much impressed.
Some tested the AR823 in the whammy results sound not so bad.
This is incredible. Love it.
Wayne's has 100 Ohms
I have an uncontrollable addiction to diyaudio.
Hahahahahaha
Edit: It's now 1:25am
Last night I went to bed at 5:35am.
Hahahaha
One suggestion for your circuit if you create a PCB from it, is to clearly mark the chassis/ground earth versus the circuit ground. The Glassware Audio board is very confusing as it calls one "house-grnd" and the other the ground symbol so I had to look at it 4 times just to make sure I was hooking it up properly!
This arrived today.
Just a short question:
I have built a Whammy like in the first posts of this thread without any extras. I am using the LED supply version.
I was very suprised to see that the supply rails had exactly the same absolute value of 16.85V. This is just luck, right?
