To load the bootloader you will need a USBTinyISP like this. Buy Products Online from China Wholesalers at Aliexpress.com To load the actual program you will need a USB to serial adapter. CP2102 based adapters work great as long as they have access to the DTR pin to connect to the reset line. Something like this, Buy Products Online from China Wholesalers at Aliexpress.com
Ok, thanks for replying, in that case I will just have to wait .
Florin
Hi Florin, I will check with Jeff - the parts kit is planned to go from his lab.
RCA connectors, binding posts, and DSO scope are already on the way to you.
I will check if there is some info from the carrier.
Valery
Oops... missed 2 posts above
Hi Valery, I have received today two RCA connectors, I am not at home but from what my parents have showed me from the whatsapp call it looks like the two RCA connectors have arrived. I should assume that all have been shipped separately? to avoid higher cost with customs at the post office? Any news about the rest?
Thanks,
Florin
Thanks,
Florin
Thanks,
Florin
Hi Florin,
Right, all the pieces were shipped separately.
The boards, kits, modules, etc. are normally shipped from Jeff's lab in Canada. All the parts like connectors, binding posts, portable oscilloscope devices and kits, peak meters - go directly from the manufacturers in China.
As you mentioned, in some cases, it helps to avoid issues with customs.
All deliveries go slowly these days, however I hope nothing will be lost.
Anyway, please keep us in the loop on receiving the rest of the order.
Valery
Very Excited - Just ordered the parts for the kits... Can't wait!!
I've been putting together your parts kits, but I'm out of stock on a couple pieces. I hope to have them ready to ship by the weekend.
I assume you want to run on 240VAC mains? I need to send the appropriate soft start resistors.
No worries, I realise things are a bit difficult with a global pandemic going on, yes 240v is my local flavour.
Glad to hear your parts kit finally arrived (hopefully). Everything is moving way too slow lately!
It looks like your binding posts made it to customs in your country back in March but haven't moved since. If your country's like most others customs are way behind and some shipping containers just sit unopened. Here's the tracking number. UJ175168458CN
Hi Thanks, could you post the sketch that must be written into the control board please, I will start doing the board tommorow and will be usefull, I only received one of the two small boards that would connect to the controller, the small board with the USB connector without the two ribbon wires that you sugested, that would suffice the get the software written?
Thanks,
Florin
Thanks,
Florin
- Group Buys
- Simpelstark+ ODNF amplifier boards GB
